Question about Garden
How do i reseal ace sprayer model 2240
How do i reseal the tube
How do I sign in to on line banking
Go to your banks web sits click on their bank instructions for setting up a on line account, if you already have one, you will need to type in your user name and password. If you still can't get logged on, call your band for advice. Have account info ready.
Feb 03, 2015 | Ace Hardware Ace Home and Garden Sprayer
Just bought the Ace 2 gal poly deck sprayer but it will not spray just puts out a stream of stain..is there something extra I should have purchased to get this to spray ??
I had the same problem. The deck sprayers are meant for thin liquids, not the heavy stains. Some stains have a thin consistency, others are thick. You can go back and buy a thinner agent for your particular stain, but , in my experience doing that, it thinned it too much, the color was off and didnt cover right. I ended up using a roller and brush to do the job right.
Sep 19, 2011 | Ace Hardware Ace 2Gal Home and Garden Poly...
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Sep 09, 2011 | Stanley Professional Backpack Poly...
I am looking for the tube inside an ortho 2 gal plastic sprayer. It is plastic and broke. Just a straight plastic tube with a slightly flanged top to fit in the sprayer.
I am sorry for the problems you are experiencing with your Tank Sprayer. Please give us a call at 877-465-5160. Hilary @ Ortho
Aug 12, 2011 | Garden
Won't seal and hold pressure
Try smearing some Vaseline on the gasket that goes around the pump shaft at the top.
Aug 06, 2011 | Ace Hardware Acer Spray and Go Sprayer
Dishes on top shelf do not get clean.
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 13, 2011 | KitchenAid Dishwashers
Hello, I have a portable Moffat dishwasher Model: MRC3210SW159, Serial: AR608530A. We are getting small food bits stuck all over the dishes. Not sure what to take apart or do? Could you please give us some...
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
And of course, when you're loading the dishwasher, be sure none of the items are resting ON each other. This will prevent the water from circulating and cleaning.
Jun 12, 2011 | Dishwashers
Little water to top rack
Jun 12, 2011 | GE Dishwashers
I have a 2 gal ortho heavy duty pump sprayer and I'm need a new nozzel. Where can I find replacement parts?
I guess a company called the Fountainhead Group makes a lot of different sprayers other companies. They have repair parts available on their site. I replaced the nozzle and installed fresh gaskets with a kit from Lowes and with info from this site; http://www.creativeworksforchildren.com/how-to-repair-ortho-roundup-garden-pump-sprayer.htm
Aug 03, 2010 | Garden
Need help with Hudson Trombone Tree and Shrub Sprayer Model 61224
There's a parts illustration on the Hudson web site that may be helpful to put the sprayer back together correctly. Here's the link: http://www.hdhudson.com/PDF_files/10.pdf
Jun 16, 2009 | H.D. Hudson Hudson Trombone Sprayer - 140...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
