Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer is saying it's out of paper and it isn't.
The printer was working fine, then in the middle of a job it stopped and said "load more paper." There clearly was enough paper. Since then, I've uninstalled and reinstalled, tried the "test," unplugged it, checked for any thing that could've jammed it, and now I'm here. This has never happened before. I've read about a "paper sensor," but I don't know where or how to access it. Please help me!
  • dbabuscio Jun 24, 2009
    Thanks so much! I will try it tomorrow. I feel if I'm defeated once more tonight I may "hurt" the printer. :-)
    President:
  • 2,306 Answers
More than a paper sensor, usually the paper feed tire is dried out or coated with paper dust and stuff. A damp towel is the best, with just water as alcohol will further dry out the rubber. Take out the paper and look for the rubber tire that pulls the paper in and wipe it on all areas as you turn it, let it dry. Usually the printer thinks it's out of paper if none is fed in at the proper time. Take off the back cover and wipe those rollers too.
Posted on Jun 23, 2009
Epson wide format printer stops in the middle of a job saying paper jam. But I know it is not paper jam.
I do not know this particular printer but several things might be wrong. Make sure all the paper handling sensors and rollers are clean. Check to see if the next sheet of paper is sticking to the first and blocking a sensor. Check to see if the paper is advancing properly. Sometimes the roller will spin but slips on the paper, if the printer senses that the paper is not advancing properly it will throw a paper jam code. Make sure you are using fresh, crisp paper and the holding tray is at least half full.
Mar 17, 2016 | Epson Stylus Pro 10000 InkJet Printer
Printer says there is a paper jam but there isn't
Please insure that the paper sensor flag is still in it position. Open the printer and look about in the middle to see the flag. Feel if it moves freely.
Mar 14, 2012 | HP Office Equipment & Supplies
Print job stops in the middle of a print job
first if its happening from few days than go for system restore - start - all programs - accessories - system tools - system restore.. select that date on which it worked fine.. or else add printer and install deskjet 990c and than try
Oct 14, 2009 | HP DeskJet 722c InkJet Printer
The printer suddenly stopped printing in the middle of a job. Now whenever i try to print it says job waiting and when i try to delete the current prints it says deleting but stays on saying that and...
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 05, 2009 | Lexmark Z640 InkJet Printer
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon Mx300 wont recognize my paper. says:load paper
I cant print...orange light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
556 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
