Question about Boating
How do I remove water pump from honda bf115 hp out board motor year 2005
    Top Expert:
  • 43,059 Answers
That size motor I would pay the dealer to service .
Posted on Aug 12, 2014
3 Suggested Answers
  • 106 Answers
SOURCE: how do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Posted on Aug 19, 2012
richsteve777
i know i need a knew cable i put in trouble shooting for all how do i install it the cable is broke i know that. because it broke down below on the motor i dont know where it hooks up on the top of the motor 1990 40 hp evinrude model number is te-40-elesr cable tilt assist.what dont you guys understand. where can i get a diagram where the cable hooks up on the motor. duh
Posted on May 19, 2014
Honda 4000 motor runs great, pump not preasuring up water changed pump and no change, shaft from motor into pump was good felt like it was under compression but still no preasure
The pressure relief valve could be stuck open or faulty. The check valves may be stuck or plugged up. Try thoroughly clean these parts and see if that helps.
Bob
Mar 31, 2015 | Honda 13 Hp 4000psi 4gpm Pressure Washer...
2005 bf115 hp honda weater pump repair
this is best left to the dealer .mistakes get real costly
May 18, 2014 | Boating
How to replace piston rings on honda 6 horse motor
you need to remove the pump then the end cover from the engine remove the cylinder head the unbolt the connecting rod push out the piston hone cylinder and then wash the motor out with soap and water i use tide clothes soap and hot water put it back to gether now why does it smoke check the head gasket the over head engines blow head gaskets and **** oil from the crankcase
Aug 06, 2012 | Honda Garden
I have an above ground pool with a jacuzzi pump. (1.5 hp). I just replaced the sand in the sand filter. I also put on a new o-ring on the jacuzzi pump cover. When I turn on the filter, the pump fills up...
I think you have a air leak. A 1.5 hp motor is very strong and should vacuum well. Be careful to not over tighten the top of your pump housing.
Is your impeller in good shape? It may be worth your while to remove the pump motor from the pump. While you have it apart, replace all the seals (there is a kit for this). Inspect the impeller and all parts of the housing - any junk inside? Remove it. After you complete the rebuild, reinstall the motor, fill the pump housing with water, secure the top and start the pump.
Let me know what happens ...
thanks for your interest in FixYa.com
Jul 03, 2011 | Jacuzzi Pool & Spa
WHERE IS THE WATER PUMP LOCATED ON 1994 HONDA ACCORD EX?
On the driver's side of the motor you can find the water pump almost directly below the side motor mount. All you will see is a small nipple that is actually a "weep hole" opening that will leak to let you know the water pump is bad. To remove it you need to be ready to remove your crank pulley, timing belt cover, the motor mount and your valve cover to get the top timing cover off. It is best to change your timing belt at the same time. Your supposed to do both at about 125k miles.
Apr 28, 2010 | Honda Accord Cars & Trucks
Lossing water out of small hole on under side of motor ? Normal or not
Not, sounds like a seal vent for the water pump, shouldn't leak.
Jan 07, 2010 | 2005 Honda CRF 450 R
How to remove water pump from honda 450x 2007
Remove impeller using a 10mm socket. It is a standard thread so nothing special needs to be done.get back to me if need more info270204a.jpg
Oct 11, 2009 | 2005 Honda CRF 450 X
Need help to remove 2005 Scion xB water pump
1st ...that should be covered under 6 year 50k power train warranty from the dealer.
But if your over....you need to unbolt the right side motor mount (on the water pump side) and lift the engine some with a floor jack to get clearance,
Feb 21, 2009 | 2006 Scion xB
CE Code On 6 year old Calypso
Check the fuse on the motor control board and see if it is blown. If so, You could just have a bad board, but it may be a drive motor or pump motor. The most common thing is for the pump seal to leak into the pump motor and cause a short.
The CE code means the 2 boards can not communicate with each other so be sure to check the wiring connectors between them. Post back with what you find out.
Oct 23, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
