Question about Maytag MSD2756G Side by Side Refrigerator
Good evening, My Maytag refrig/frez s/s model #MSD2756DE is very warm inside. This started after a thunder storm. It's making a clicking sound every 2-3 minutes. It sounds like a compressor wants to start but cannot. The freezer and refrig level inside the the refrig is set to 6. Any ideas gentlemen? Von Wolfgang vonwolfgang@yahoo.com
  • 79 Answers
Sorry to tell you this, but your compressor is stuck, your chance of getting the compressor unstuck is about 1%. Companies warranty their compressors for 5 years on the average. If the fridge is older than that, it doesn't pay to have someone replace it, it would be time for a new fridge.
Posted on Jun 24, 2009
Maytag model MBR2258XES4 refrigerator and freezer not cooling well d
I had a similiar problem with mine..it ended up being the defroster board..it seems to kak out every 3 yrs..mine was under the temperature control panel..it was in a white box inder the cover..good luck.
Mar 25, 2014 | Maytag MBR2258XES Stainless Steel
My yamaha htr 5250 suffered a shock from thunder storm, no sound out of channels, just humming
The thunder storm has damaged the audio output semiconductors, replacement of parts only option to correct.
May 21, 2012 | Yamaha Htr-5250
I have a fischer pukle fridge making a whisling sound after a thunder storm
It maybe just coincidental that the noise appeared after the storm. However, if carbon deposits caused by an electric ark have created interference to something like the fan motor bearings. One would that any associated electronic device would not function either, if fitted.
Nov 18, 2011 | Fisher and Paykel Refrigerators
Model # msd2756de freezer and fridge stopped cooling, Christmas Day!!!!!!! unloaded freezer, fridge overnight the temp the next morning is 15 in freezer and 50 in fridge. moved thermostat back and...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Maytag Refrigerators
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a 10 yr old Maytag side-by-side. Came home the other night and the Freezer was at 40F. What is the most likely problem
to start: make sure refrig is turned on and running.
1.do you hear the fan blowing inside the frzr compartment?
2.pull refrig out and listen for compressor running. is compressor running/humming away or are you hearing a humming sound followed by a clicking sound?if you hearing a clicking sound than mostly
is your relay on the compressor that went out. look for a smal device on the side of compressor w/two or three wires. part# 12002794 $32.00
also make sure there's no frost build on frzr rear wall.that's another problem
Jul 15, 2009 | Maytag MSD2758GEW
I have a maytag side by side refrig., model number msd2432gr. The unit is on and running but not cooling, making clicking sounds like it's trying to do something.
I have honestly had the same problem, if the compressor is ok it has to be the start capacitor. I can help you repair even if it is the compressor. Hope I can help you more
Dec 17, 2008 | Heating & Cooling
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
My samsung model- HCN4226W T.V will not turn on
You should always have all expensive electronics on a surge protector. It sounds like for this set the power regulators blown out as I know this set very well and seen it a hundred times!! its a power regulator IC that cant handle a power surge at all. and if thats your only problem, it shouldnt cost more then 175.00 to 250.00 to repair. Now with a surge though there could be other problems as well but from what you stated Im guessing alls ok except what i stated. Now Please do not attempt to repair yoursels, as these sets have alot of Hi voltage inside them even when they are unplugged.. Good Luck
Jun 28, 2006 | Samsung HCN4226W 42" Rear Projection...
Maytag MSD2756G Side by Side Refrigerator Logo
230 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
