Question about Garden
Craftsman 944 why craftsman lawnmower, model 944-361452. won't start . Did work fine before this.
3 Suggested Answers
  • 207 Answers
SOURCE: Hi , i have a craftsman 16hp model 944 602261 the
When you engage the blades you are putting an extra load on the engine. This mean it needs more fuel and more air to keep running.
I suggest cleaning or replacing the air filter, it may be clogged just enough to let the engine run with little load, but when you put a load it cant get enough air. This happened with my string trimmer this summer.
If that doesn't fix it then I recommend pulling off the carburetor (between the air filter box and the engine), taking it apart and cleaning it with carburetor cleaner. If its getting enough air at full load then it isn't getting enough fuel, there could be a partial blockage of the jets inside the carburetor.
Posted on Jun 10, 2011
  • 11 Answers
SOURCE: craftsman model 536270211 13.5 hp ride on lawnmower won't start
check for water and debrie in float bowl and spark at plug
Posted on Jun 07, 2012
Craftsman model 944-364350 lawnmower with electric start. How do you replace the battery?
1) Find the battery.
2) Unhook the terminals using the appropriate tools.
3) Disconnect the battery from the battery hold-down, using the appropriate tools. You may need a good light to see what you are doing.
4) Lift the battery out of the holder.
God bless your efforts.
Feb 13, 2017 | Craftsman Garden
Have a craftsman 2008 ish LTS-1500,17.5 horsepower silver edition. SErico # 060810c001380.Checked model number for parts,Sears says model # 944.600081 does not exist. Any help with model number for parts...
I have numerous users looking for help with various models that have the 944 prefix over the last 6 months. The problem is with Sears in Canada on this. For some reason they are not putting the 944 models on the parts look-up system that is available on the net..
You can try calling their parts and service number. 1-800-469-46637:00 am - 10:00 pm EST
Mar 17, 2015 | Craftsman Garden
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
New mower won't start
new mowers come without oil so fill with lawnmower oil and with fuel then prime and start
Jun 16, 2012 | Craftsman Garden
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Manual for a Craftsman lawn mower model # 944-364522
Have a craftsman 17.5 riding, replaced battery, solenoid, and starter. Stater will not engage.
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
