Question about Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles,
Why am I getting an LF code at 19 minutes on cycles and then it will not finish the cycle
SOURCE: lse 1000 WASHER get L
I'd love to share the solution with you. But first I'd like to offer you the premium assistance plan. By using this plan you get the solution on how to solve my problem.
Posted on Jun 24, 2008
VOTIT
  • 2071 Answers
SOURCE: Final spin cycle issues
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
HOPE THIS MAY HELP YOU;
Regards,
VOTIT
Posted on Sep 07, 2008
dh1200s
  • 335 Answers
SOURCE: nf error cycle won't finish-maytag neptune TL
NF = No water fill. I haven’t had this failure to date but this how I would troubleshoot. Could be a block at the water valve inlet screens where the supply hoses connect to the machine. Check to see if the washer fill screens are blocked, It could be a failure of the Cold/Hot water solenoid valves. I would try to fill with hot water if no fill try cold only.
It might be easier to go into Service Mode to turn on and off the water valves while troubleshooting this issue. Enter Service Mode and use the keys assigned to the table at the bottom right side of page 16 of the FAV6800A/9800A Service Manual . Do this check only if you feel qualified, if still no water fill after the above checks I would break out my DVM and check for 120VAC at the water inlet valves. Post Back if you need additional help. Rich
Posted on Apr 21, 2009
SOURCE: error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Posted on Apr 26, 2009
Krazytech
  • 725 Answers
SOURCE: Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
The washer is not finishing cycle shows the code LF
LF = Long Fill
Is water supply connection turned on.
Are hose screens plugged? ( these are inside the inlet on the machine where the hoses connect )
Is water entering the tub? If so, check the pressure hose connection to the machine/motor control. This is the main control unit. There is a service manual inside the machine. If you open the top of the unit with a screw driver in the front, the manual should be on the inside of the front panel.
Aug 17, 2011 | Kenmore Washing Machines
Letter LF appear where the time should read. The washer just beeps and does not finish the load
This is a long fill (LF) check the inlet hoses for the screens being clogged...if it takes longer than 10 minutes to fill ..it cuts off and shows LF ..check that either water valve is not turned off or almost turned off...also, alot of people just use cold...make sure the selector is set for cold/cold if using this cycle...another possible fault is the mixing valve is bad/or going bad..Either way consentrate on this and you'll find your solution
Bruce Denton
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
"LF" Long Fill Fault Code on Whirlpool Cabiro HE Washer
there is an electronic timer, did they mention how long the fill should take on average and when the timer signals fill time exceeded?
Sep 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LF code appears and washer does not spin out
This is where to find the manual. When you get to it, it tells you that LF is for long fill which means it is taking longer than ten minutes to fill with water so it shuts off and displays the error code.
Bottom Line : Check your water pressure.
Aug 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles, Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
