Question about Acomdata mini Pal HD320FPMM-72 (HD320FPMM72) 320 GB Hard Drive
I had my 160GB Acomdata Mini Pal go down on me. My computers do not acknowledge it anymore no matter any different tweaks I have made with cords and connections. I need to know if there is a way to retrieve some of the data before I go and buy a new hard drive. Joe Bobbe
SOURCE: acomdata hard drive doesnt show up on my computer
I have the 250 GB Acomdata drive. Had the exact same problem--computer would not recognize drive; blue light on drive lit and drive making a slight whirring/clicking noise. I read somewhere that some people that have had this problem have found the problem is with the USB interface between the drive and case, NOT with the drive itself. I took the drive out of its case and installed it in a desktop computer and was able to get all of the data off of the drive.
Posted on Dec 31, 2008
Chinthakaj
  • 416 Answers
SOURCE: Can't open hard drive enclosure
A Details Guide too remove the Disk.
http://www.gearhack.com/myink/ViewPage.php?file=docs/AcomData%20E5%20HybridDrive%20External%20Hard%20Drive%20Disassembly
Posted on Feb 02, 2009
Crankstart
  • 696 Answers
SOURCE: flashing red/blue acomdata 1 terrabyte external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
PC Commando
  • 142 Answers
SOURCE: red and blue light alternately blinking. What can i do.
Remove the drive from the enclosure and either install it in your machine as a slave or you will need to buy a new enclosure and put the drive in it.
Posted on Sep 17, 2009
Geekinator
  • 183 Answers
SOURCE: External Hard Drive not showing on My Computer? [URGENT]
Hello there Mansoor.
First, I have to commend you on how clear and extremely well articulated your problem is presented. You give every detail necessary to grasp your current situation. Good job! I can also clearly see you're at least a fairly proficient user. I only wish I'd reviewed your question before now, so I could have replied sooner. That notwithstanding, here's my GEEK-steer ...
Good job testing the drive against other "known good" systems. Because (as you probably already know) based on that, it's a virtual certainty it's the drive itself that's the source of the problem (UNLESS you used the same USB cable in all tests ... rule that out by using a "known good" cable). Its trouble could be caused by any number things [e.g., deleted partition, virus related, "sector" (file/folder structure related) errors, etc.]. At this point you've utilized all the tools that Windows avails you to work this problem (e.g., you obviously can't perform a Windows "chkdsk" on it unless there's an assigned and known driver letter, "Disk Managment" was no help, etc.). We therefore need additional software tools in order to proceed further.
Per the manufacturer's webpage, "Acomdata does not have any Windows XP, Windows Vista or Mac OS drivers because all products use the built-in driver support already supplied by the associated Operating System". Therefore, they design all their devices to be supported by Windows' database of generic drivers. However, here's their offered driver package for "All Platforms". It's a long-shot, but it couldn't hurt to start by giving this driver a try (you can always "Roll back driver" from within "Device Manager" if necessary).
== CAPTURE AN IMAGE BACKUP ==
If, as you state, data recovery is of the utmost importance, then I would strongly advise your very first objective to be (if at all possible) creating an image of the problem drive, then backup that image onto another drive. I would do that FIRST to lock in it's current state as an insurance policy, BEFORE I ran any testing/diagnostics, or attempted any alternate means of data recovery. Keep that image intact throughout this process until resolution. There are several disk image "Backup Tools" (e.g., "DriveImageXML", "Acronis True Image", etc.) in "Hiren's Boot CD" you can use to accomplish this.
== BREAK OUT THE TOOLBOX ==
Refer here for complete list of its available tools. There are far too many to cover in any detail here. Particularly when the nature of your problem is yet known, as each may, or may not be THE one for the job. However, you can simply Google each to obtain background and usage instructions. Also, tools reside in either the DOS or mini-Windows boot portions of the CD, as some are DOS executable and some Windows. You may have to venture into both until you find the tool that works for you. I know there's a lot in that puppy, but that is intentional because it's a good thing ... affords wide range of choices/options.
== HOW-TO CREATE 'HIREN'S BOOT CD' ==
  1. Download "Hiren's Boot CD".
  2. Extract/unpack/unzip/decompress (<-choose your term, they all mean the same thing) the .ISO disk image file ("Hiren's.BootCD.#.ISO") located within the downloaded "Hirens.BootCD.#.zip" archive file (where # = version of Hiren's).
  3. Burn the disk image to a CD using whichever capable disk image burning software (e.g., Nero, Roxio, etc.) you may have. Don't have one? Then download and install the very capable, yet lightweight FREEWARE "imgBurn"
Burn the extracted .ISO image file ("Hiren's.BootCD.#.ISO") to CD using imgBurn:
  1. Insert a blank disk (R/RW) into your disk burning capable CD/DVD drive.
  2. Launch "imgBurn", then select "Write image file to disc".
  3. Browse for and select the "Source" .ISO file above.
  4. Ensure the applicable disk burner drive is selected as "Destination" (you may have more than one).
  5. Click the burn icon.
  6. When burning completes, close "imgBurn".
== RECOVER THE DATA ==
Next I would attempt recovering the data using any number of Hiren's "Recovery Tools" category of tools (e.g., "ProSoft Media Tools", "GetDataBack for NTFS", "TestDisk", "Ontrack Easy Recovery", etc.). Many of these include diagnostics/repair facilities you can use in the course of your recovery efforts.
== RECOVER/FIX THE DRIVE ==
Then once/if you've successfully recovered the drive's data, you can (if applicable) use any number of Hiren's (hard-drive related) "Testing Tools" and "Hard Disk Tools" categories of items in order to fully test/diagnose and hopefully recover the drive to working order.
TIPS:.
  • Be aware that you MAY discover you'll HAVE to perform testing/diagnostics/maintentance related actions on the drive first, just in order to get it into recognizable shape for any of the drive image and/or data recovery related tools to perform. That's OK, 'cause "you gotta do, what you gotta do".
  • "Partition Find and Mount" might be particularly helpful in recognizing, then mounting the drive
I apologize in advance for any logic-sequence or grammatical errors this reply may contain. I culled together a few differing draft stage portions of some "Tips & Tricks" I'm intending to post in the near future.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 09, 2009
My windows 7 (x64) will not Acknowledge My AcomData HD250FAPE5-72 External Hard Drive, What do I do.
Having looked at the review of this device, it doesn't sound good. There is a problem with these but if it shows up in explorer you can use it. The other problem is that it is not windows 7 recommended. Have you tried to use it with the firewire connection? You may have better luck, but Windows 7 has to have "Signed Drivers" for all hardware (they have to be vetted by Microsoft) Good luck.
Mar 20, 2012 | Acomdata Computers & Internet
I have a 160GB signature mini external harddrive. It has been working fine for months but all of a sudden my laptop won't recognize when I plug it into the usb port. The red light comes on to show that it...
It sounds like your hard drive is dead. If you have tried it on a different computer and it did the same thing then your drive isn't booting up and is probably bad.
Aug 09, 2009 | SimpleTech Signature Mini 160GB External...
Simpletech External Drive now failing to connect with USB 2.0
Hello sir, let me give you some tips, you can dismantle it and get the HDD unit, buy a cheap external SATA usb hdd enclosure with USB 2.0 . Well all of them are 2.0 compatible (the unit without the HDD) and put it there. you can always keep the old one for posterity. hope this helps.
Aug 06, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Broke external hard drive
It depends on how badly bent it is. If you're stable with your hands, and can use a small nail to pry the deformed peice straight, do so carefully. If however you absolutely need to save the data on the drive and can't afford to have the bent peice fully break off, take it to your local computer repair store and they should be able to replace the connection.
May 05, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Computer does not recognize the external harddrive
try installing the drivers on your computer for it from this website
http://list.driverguide.com/matches.php?h=932a9713352aa24ea0444960cf489ad2&ids[0]=1119263&ids[1]=1119260&ids[2]=1119267&cid=1256&model=HD160UE5-72 - E5 - 160GB
May 23, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
AC Adapter
Hey thats one of two things your (internal charging unit) if so your SCREWED if not its the sowtware issue witch means you gotta tweak the settings especially if you just upgraded your OS if tweaking doesnt work then re-install your OS then set your OS setting Correctly to the best of your knowledge have fun...it take a bit of patience and a couple hours i had the same prob.....seeya
Oct 28, 2007 | Dell Inspiron 2200 Notebook
Acomdata mini Pal HD320FPMM-72 (HD320FPMM72) 320 GB Hard Drive Logo
137 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
Tom
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
