Question about Nokia 6255i
Broken housing on 6255I
I have two Nokia 6255I phones, in really good working condition. But the housing on each is broken, (hinge). I would like to find a place where I can get new housings and find out how to take them apart and replace the housing.
  • fwstanly Jun 23, 2009
    i have checked with several repair shops in the Dallas area, none of them seem to have the casing/housing or seem to want to find them. I think I can find the housing online if I just had some instructions on how to remove the old and replace with the new.
  • fwstanly Jun 24, 2009
    well that will work great but I need to replace the whole housing case, the ear part and the key pad part. THE HINGE IS BROKEN and since its a flip phone, if the hinge is broken, it don't flip. You flip it, you now have two parts in your hand. I have replaced the faceplate cover twice already, i need to replace the rest of the housing.......... But we are on the right track here
    President:
  • Nokia Master
  • 2,923 Answers
The best suggestion is to bring your phone to the nearest Nokia Care Center. Or you may wanna check any cell phone stores. There should be an available casing/housing in any cell phone stores.
Have a good one!
Posted on Jun 23, 2009
  • Melvin Ramos
    Melvin Ramos Jun 23, 2009
    Okay, you will need a T6 tool:
    #1. Open your flip phone take the career logo/ Nokia logo off.
    #2.
    Unscrew one T6
    screw and pry the faceplate off your phone; make sure not to pull the
    cover off suddenly after it becomes loose, rather gently remove it.
    #3.
    Place your new faceplate on your phone and squeeze 4 corners till clicks on.
    #4.
    screw on one T6 screw back on and replace the batter door.
    Check this link and maybe you can order a housing:
    http://www.himfr.com/d-p1166426363156139...
    Have a good one!
Nokia 6255i network problum
two solutions
1 open the top cover which has aerial & see if it is attached with the phone board if not buy new nuts & tighten it will start working
or hardware problem
Jun 24, 2015 | Nokia 6255i
How do i use my nokia 6255i as modem?
Install the nokia pc suite, from nokia.co.in
After installing the ovi suite connect your phone to the computer using an usb chord. Check the option to connect it using pc suite.
The pc suite you installed will automatically recognise your phone. In the ovi suit there is an option to connect to the internet using the phone. That is it can be used as a modem.
Dec 04, 2010 | Nokia 6255i
I dropped my nokia 6131. now the mini display is not working: it's upside down and not showing caller id. + the flip is not answering the all when opened
one of the problems with the flip phones is they are very easily broken at the hinges. try taking out the battery and then restarting it. there are several very tiny wires that go through the hinges, and if one of them is broken, not much you can do unless you are very good with cells. only a shop could fix, unless you have insurance on your phone. if not...... new phone.....argggg
Feb 03, 2010 | Nokia 6131 Cellular Phone
Nokia 6255i mini screen light won't go off
go to the settings set the light AUTOMATIC,, do not choose ON,, if it will not work you must go with the warranty of it, it is the format programmed of your cellphone that will not allow to enable light,
regards JAN_yuanjia
Nov 27, 2008 | Nokia 6255i
how can i get the keypad ights on nolia 6255
Feb 19, 2008 | Nokia 6255i
Nokia 6255i will not turn on
Probably noting wrong with the battery, might be a hardware issue, I recommend you take the phone for analysis to a phone shop.
Feb 12, 2008 | Nokia 6255i
REPAIR NOKIA 6255I
bagaimana sih format nokia 6255i, menggunakan *#7780# masih aja tidak hilang applikasi yang ada di hp
Jan 17, 2008 | Nokia 6255i
IMEI number
use *3001#12345# then look to serial number
Jan 08, 2008 | Nokia 6255i
IMEI NUMBER FOR NOKIA 6255i
look it on your Guide Book or your phone's box
Nokia 6255i Logo
122 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
