Question about RELIANCE ELECTRIC WATER HEATER
Why does my reliance water heater relief valve leak?
  • Reliance Master
  • 5,089 Answers
  • 71 Answers
SOURCE: Reliance gas water heater 40 capicity, has a leak on the top
Most likely only one of the pipes is leaking but weaping enough to cover the top and indented places near both inlet and outlet. This leak has most likely penetrated all the insulation and is a problem throughout the tank wrap insulation...If you are able to blow air continuously long enough to determine which connection is leaking then fix it. It will likely to take quite a while to dry out all the insulation if the water has migrated down into the tank wrap... If you determine that the insulation is waterlogged, you may be able to drill several small holes in the external cover.
good luck
Posted on Jan 06, 2009
SOURCE: Could you please tell me how to open the T&P
can i use this camera as a webcam?kodak m873
Posted on Jun 10, 2009
snap101
  • 117 Answers
SOURCE: My electric reliance water heater is making a constant noise
it might be hard water in the heater. the hard water flakes and when your water heater turns on it creates some movement in those hard water flakes and makes a popping and hissing noise then when it comes to temperature it should stop. the temperature and pressure relief valve shouldn't make this noise. but if you stick your finger in the pipe and it is wet then you might have problems some where else. let me know if it is
Posted on Jul 29, 2009
  • 82 Answers
SOURCE: need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Posted on Jan 31, 2010
SOURCE: I have a Reliance water heater - 40 gal Model
In my first 15 years as a plumber I never saw a pilot light issue on a gas WH that a new thermocouple didn't fix. Since the government mandated a redesign of the fire box, I've seen three that nothing ever fixed - two Whirlpools and one (my usually ultrareliable) AO Smith - including replacing the entire burner assembly and the regulator. And I've heard of many others.
Check the thermocouple connection for tight. (Don't strip.. threaded soft metals.)
Check the microvents on the bottom ? of the burn box for dust, even if it is new.
Call Reliant and demand new units until you get one that works.
Try another model. Consider a 52gal electric.
I've always recommended gas over electric, and AO Smith and Rheem were my recommendations (and "Reliants" were "lumber yard" water heaters. Sorry.)
Since the mandated redesigns, I don't really have a "proven reliable" model to suggest. I increasingly believe the restricted air flow design is the ultimate culprit, including any changes to the thermocouple/regulator construct to accommodate the restricted air flow design. Just my hunch.
Offered for what its worth. -- plumber in Indiana.
Posted on Jan 11, 2011
The reliefe valve opening on my reliance 606 gas water heater is hissing. what could be wrong?
thermostat.Check Settings,and if you turned it up or down while power was still on, thenchange them both. also t+p valve may be weak from temp overshoot.Change it if it continues after replacing thermostats
Aug 21, 2014 | Reliance 606 Series 40 Gallon Natural Gas...
Leaking water heater around relief valve
You can change out relief valve to stop leaking. Sometimes they get debris stuck inside and will not close properly.
Jan 12, 2013 | RELIANCE ELECTRIC WATER HEATER
Is my water heater leaking?
You have water leak that you can hear running water.
Could be broken pipe under house.
Could be water running out of tank at TP valve.
Turn off all water taps and put ear against each pipe at tank.
If TP valve is leaking, then replace TP valve.
If pipe is broken under house, then call contractor.
Copy following links for troubleshoot walk-thru.
http://waterheatertimer.org/images/Ear-against-pipe-200.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
Aug 28, 2012 | Reliance 606 Series 40 Gallon Electric...
Water pouring from overflow pipe into kitchen. We have Reliance Water heater TPR 15 (5254-c) model
the pressure valve is bad where over flow pipe hooks to. go to a place where they sell heater parts, and buy a new relief valve!! good-luck!!
Nov 12, 2010 | Reliance Water Heaters
I have a Reliance 501 40 gallon water heater leaking warm water from the valve at the top of the unit. Steady leak. What should we do short term, and is there a part we can get to fix it?
i am not sure if you are talking about a shut off valve or the pressure relief valve. the relief valve should have a pipe from it going down the side of the water heater. if that is the leak the it can be replaced. there should be a little lever on top of it and some times by lifting it and letting a little water flow through, it will stop leaking.
Oct 19, 2010 | Reliance & 50gal Electric Water Heater
Water leaking from overflow.
This is not an "overflow". It is a Temperature/pressure relief valve. Sometimes they leak with age or build up solids in valve preventing them from closing completely. This is the single most important safety device on your water heater. If one of the thermostats is malfunctioning, the TPR valve will relieve. If the pressure rises too high, it will also relieve. You can replace the valve, but be sure it is the same temperature and pressure rating. You will need to turn the water off and drain some of the water prior to removing the valve. Don't forget to reinstall the down pipe that directs floor to floor or drain. If a new one leaks also, suspect your temperature control. Water heaters can be bombs if the safeties are not working properly
Oct 02, 2010 | RELIANCE ELECTRIC WATER HEATER
Need to empty reliance 501 hot water heater how?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
Jul 29, 2009 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
133 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
