Question about Philips Irons
How to open a philips iron - Philips Irons
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
How do i open screws
broken studs for screw tightning,cant repair without expert,there is one screw under main wire side,second is under pressure knobs to open it
Dec 18, 2014 | Philips Gc2910/02 Powerlife Steam Iron,...
Philips iron keeps turnning off
We have the same problem here. The station only switches off after some time, but the iron itself keeps being switched on. So you manually have to switch on the station many times during ironing which is very annoying (for my wife). This was working before and we have tested here on different circuits already.
Sep 01, 2014 | Philips Gc8340/02 5 Bar Steam Generator,...
Philips manual
You should clean your Philips Steam Iron. Follow the video guide given below to clean your iron
Aug 16, 2014 | Irons
The electrical at home trips everytime I swicth ON the AZUR4330??
Hi
I know its hard to say... But please get a new iron....
You me y do more harm to other electricals just trying to fix the iron....
I know this is not a great solution byt a pratical one...
Warm Regards
Berry
Feb 02, 2010 | Philips HI-296 Iron
Lost the details on how to clean Philips GC2540 iron. Please can you provide some information.
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 18, 2009 | Philips Irons
Philips easycare 3232 needs cleaning and iv forgot how to do it
I run vinegar through my iron and iron on a white towel using the mist and spray to "work out" all the residue. Then I use plain water again to make sure I have removed all the dirt before ironing anything delicate.
Jan 04, 2009 | Irons
Help
heres a link so you can get more information for your product , hope this helps AJ .
http://www.shopping.com/xPP-irons-norelco~LO-1~CR-0
May 17, 2008 | Philips HI-296 Iron
Philips Azure self-cleaning steam iron
philips do not have a manual for this iron online, sorry contact them if you want; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?sct=IR_STEAMIRONS_SU&cat=HOP_IRONS_CA&grp=HOUSEHOLD_PRODUCTS_GR&session=20070313063306_83.37.63.254&ctn=HI296/54&slg=ENG&scy=GB The best way to clean these irons is with neat vinegar - try to get white vinegar and you have less smell to get rid of - fill the iron, give it a good shake and leave it overnight, then use the iron as normal (use it on a kitchen drying up towel or similar) then leave it for another few hours/overnight and then empty out any remaining vinegar and rinse through with water a couple of times. this normally solves any problems caused by limescale - if not then just leave the iron a little longer with the vinegar, also try to pour a little vinegar into the steam vent holes with the iron upturned and leave for a while. Hope this helps :)
Mar 05, 2007 | Philips HI-296 Iron
Irons Logo
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
