Vizio e370va logo is flickering and won't turn on?
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
  • 517 Answers
SOURCE: tv won't turn no the vizio logo only blinks
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.
Posted on Jun 11, 2011
chesterpendi
  • 195 Answers
SOURCE: Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
I have a vizio tv...i can see the vizio logo light up but wont turn on...
Corrupted firmware. A firmware update is necessary. Contact any service technician.
Nov 21, 2015 | Vizio VO Televison & Video
Vizio sv41xvt flashing logo. won't power up
Sounds like either a power circuit board or mainboard failure. I'm going through same problems, mine is power board failure.
Jan 11, 2013 | Vizio SV471XVT 47 in. LCD TV
Vizio M420NV Wont turn on
I have a suggestion if you have and are using a box of some kind with this set, remove set and box from power for awhile and then power both back, sometimes a box can trigger this type of event, hope it helps and it cannot hurt to try.
Dec 11, 2012 | Vizio m420nv 42 in. LCD HDTV
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Missing screws for detachable stand for vizio e370 va
Try to contact (says your set is Vizio here) the company who made it...Also try to GOOGLE MODEL NUMBER OF SET WITH "MOUNTING BOLTS"
Mar 24, 2012 | Vizio E370VA 37 1080p 60Hz LCD HDTV
Good day!!!!
Nov 22, 2011 | Vizio E550VL 55 in. LCD HDTV
Tv won't turn no the vizio logo only blinks
Jun 06, 2011 | Vizio L32 32 in. LCD HDTV
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
