Question about Jandy Air Energy Heat Pump - 100,000 Btus
What is the Jandy heat pump high refigerator code
    Diehard:
    Visited the website for 60 consecutive days.
  • 121 Answers
Sounds like your not getting enough water thrunthe heater or your sensor is bad.
Posted on Apr 04, 2017
2 Suggested Answers
  • 246 Answers
SOURCE: We have an AquaLink RS4 All Button control in the
can't be made the only is to cancel the delay on the back dip #4 heater cool down turn off breaker when do this also change assign jva at system setup
Posted on Sep 13, 2009
How do i correct a "high limit switch circuit is open" code
check the fusable link for voltage on both sides if not replace also check pressure switch
May 26, 2014 | Jandy LX 400P Lo-NOx, 400,000 BTU Heater...
Error code High Ref Pressure on a jandy AE 3000T-R
Make sure your water filters are clean and if you have an external by-pass, make sure it is not open. High Ref Pressure is normally caused when the refrigerant is not cooled off by the pool water circulating thru the heat exchanger. If your filter pump is not circulating enough water (normally around 40gpm) in the system then you will trip the high pressure sensor. If the HP sensor trips without the compressor engaging the try replacing the sensor.
Oct 26, 2012 | Jandy Pool & Spa
High pressure light is on , on air enegry heat pump, what do i do?
What I would do if a customer of mine had this issue is be prepared to take the heat pump apart and to connect my refrigeration gauges to the system and call Jandy technical support at 800-822-7933 and they might be able to help me determine what is causing the issue.
Please let me know how this progresses. Thank you.
Aug 30, 2011 | Jandy Air Energy Heat Pump - 100,000 Btus
Jandy AE-TI H20 error message - pool not heating
just looked at the manual for this unit. It does not list an H20 code. Is this all it says on the screen?
Nov 13, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
High Refridgerant Pressure
I was able to find the manual online which had the solution in the troubleshooting guide.
Jan 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy Air Energy Heat Pump - 100,000 Btus Logo
160 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
