Question about GE Refrigerators
I have a GE TFX22JR The freezer is 15 degrees the fridge is not cooling Whats the problem?
  • 1122 Answers
SOURCE: fridge was in storage 4months fan work but not freezing.
is there ice building up in back of freezer?mike
Posted on Nov 11, 2008
SOURCE: Freezer and Fridge side not cooling
check the condenser is not blocked with fluff, it is situated iether behind the lower front trim panel or in the back near the compressor depending on the exact model also ckeck the fan near the compressor in running freeley.
Posted on Sep 01, 2007
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
  • 16 Answers
SOURCE: GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Posted on Jun 10, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile PSC25 won't cool past 45 degrees
With that model that is a sign that defrost is not happening on time or the beginning of the problem. Temperatures in fresh food compartment above 38 are not safe. Look into the back of the freezer compartment and let me know if you see a frost line buildup. If yes it would be a good idea to manually defrost the freezer so you can remove the rear panel and check the defrost heater and defrost thermostat. It's also important that with this model that the problem be resolved quickly. I can help you if you want. The defrost heater will be easy to see if burned out because it has a glass tube around the heating element. If you replace the defrost heater you should also change the defrost thermostat. Fan motors going bad on that refrigerator seem to always damage the control board and if the board is replaced the the fan motor should also. Let me know if you want me to help you, Thanks, Sea Breeze
Posted on Nov 15, 2009
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
The freezer is 10 below but the fridge wont cool lower than 52 degrees
heatman101
Sep 08, 2010 | GE Refrigerators
Refrig does not cool to only 45 degrees Freezer is
heatman101
Sep 08, 2010 | GE 18.2 Cu. Ft. Top-Mount Refrigerator -...
Refrigerator temperature is set at 37 dgrees but the temperature has gone up to 60 degrees. Freezer is ok
heatman101
Icemaker not completly filling. Freezer not defrosting, coil icing. New this AM fridge section not cool running 50 degrees. Fan in freezer running. Defrost unit replaced at some time in past.
heatman101
Aug 31, 2010 | GE Refrigerators
My refrigerator will NOT stay cold, the freezer is fine. The temp in the frig is around 40 degrees. What do you think the problem could be???
heatman101
Aug 30, 2010 | GE PTS22LHR Top Freezer Refrigerator
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
heatman101
Aug 29, 2010 | GE Refrigerators
GE side by side fridge TFX22JR not staying cold
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Nov 22, 2008 | GE GSS25LGM Side by Side Refrigerator
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
