Question about Electrolux Guardian Bagged Canister Vacuum
I need a service manual for an Electrolux C104A vaccuum. I know the part I need but don't have a part number. The part description is the hose connector at the beater attachment.
  • glincoop Jul 17, 2009
    Thanks. Any Idea where to get the service manual for the Renaisance and the 2100?
    Scholar:
  • 70 Answers
If you talking about the part that swivels it is called the elbow and the part number is 46861.
Posted on Jul 17, 2009
Can anyone sell me a scanned copy of the renaissance service manual canister is c104
Posted on Jan 03, 2012
Electrolux c104a
on line I'm guessing.
Apr 08, 2014 | Vacuums
I have a Renassiance C104A and once you plug it into the wall socket, it starts to run and no lights are on the handle....I've replaced the circuit board in the handle and the triac inside the...
There are a lot of things that could cause this problem because the wire runs through the hose. There is a connection on both ends you should check to make sure they are clean.
With the machine running try to "wiggle" the hose connections to see if the head gets power intermittently
Oct 16, 2013 | Electrolux Guardian Bagged Canister Vacuum
HOW TO TAKE APART THE electrolux el8502 vACUUM
go to the next web and proceed according:
http://www.ehow.com/how_4761328_change-belt-vacuum-cleaner.html
God bless you
May 09, 2012 | Electrolux EL8502 Versatility Bagless...
On my M&S Air Vac AV425 central vaccuum system, the system usually turns on by inserting the vaccuum hose into one of the vaccuum outlets. However, it now runs continuously. I am able to turn it off...
we are a central vacuum service company and we service all of new jersey. sounds like you have a short some where that keeps your unit running or it could be your relay module thats stuck our number is 908-721-7595 its j&j central vacuum services
Dec 28, 2010 | Vacuums
I HAVE A MODEL C104A ELECTROLUX RENAISSANCE AND IT JUST STOPS WHILE YOU ARE VACUUMING BUT IF YOU PRESS THE START BUTTON IT WILL START WORKING. I NEED TO KNOW WHY IT JUST TURNS-OFF?
There's a very good chance that it's overheating.?
Have you made sure that ALL of the filters are clean.?
If you've ever vacuumed-up anything damp or wet, it will then begin to attract dust to the damp parts & then dry the dust out, forming a skin.
A good clean of the filters & pipes (especially at joints & bends might fix it.
As Aerus Guy says, go to the manufacturers website & see if they have a troubleshooting/fault finding guide to help you.?
Best of luck.
Dec 22, 2010 | Electrolux C101 Bagged Canister Vacuum
Electrolux canister C104A: Unit shuts itself off and LED in handle next to OFF button flashes.
I have a similiar problem, but LED light does not flash. I have determined it is a short in the hose wire. THERE ARE NO REPLACEMENT PARTS FOR THIS MODEL OF ELECTROLUX. I'll never buy another Electrolux product.
Oct 31, 2010 | Electrolux Guardian Bagged Canister Vacuum
Do you know of anywhere I can get an electrolux repair manual for the 1205 model - I need to replace a motor. I have the motor Arthur Gaucher
Electrolux does not make their service manuals available to the general public or non-Electrolux service personnel.<br /> It
Feb 24, 2010 | Electrolux Vacuums
Need replacement belt PN 43409 for Electrolux Commercial Upright
Just about any vac shop should have the belt. This belt is the same belt used in the upright vacs as well as the power nozzels. The new oem part number is 48359.
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux C104A does not turn on. won't start. No light on, no sound. Is there any fuse to be raplace and/or ?
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board2.gif could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
Jul 06, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux central vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=491377
Posted by judiths on Apr 05, 2008
Help! It works fine until I plug in a hose and then the unit surges--kind of like its breathing.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a weak motor and when it takes on a load it starts to over load and or surge – but if the motor is still under a factory warranty then contact the vendor who installed it because if you work on a unit that is under a factory warranty then it will void the warrant. It is not the vacuum inlet because that only uses a low volt wire. So if it beyond the factory warranty then contact your local vacuum cleaner dealer in your area or cal the Electrolux factory for further information and or an owner manual on the unit giving them a model # and serial # so they can download the correct service manual for you. Your motor may be in need of service but be careful that the repair and labor does not exceed the cost of a new motor.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 05, 2008 | Electrolux Central Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
797 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
