Question about Craftsman Drills
Why doesn't my Craftsman drill variable speed control work
    Problem Solver:
  • 14 Answers
Switch problem
Posted on Mar 03, 2015
SOURCE: 18 volt "brute tough" Bosch
You need to replace the trigger unit to correcxt the problem.
Posted on May 23, 2008
  • 205 Answers
SOURCE: I need a wiring diagram for a sears 3/8, variable
www.searspartsdirect.com
Posted on Mar 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: 1) No variable speed; 2) Grinding sound when using <high2speed>, although drill still works
starting with the variable speed the switch part # is 2607200457 and list for 47.58, the gearbox part # is 2606200930 and lists for 75.90 and lastly the motor part # is 2607022865 and lists for 75.90, the grinding could be the motor bearing going out or the magnets cracked, if you want to tackle this I suggest going to Boschtools.com and on the left side towards the bottom type in your model number so you can look at a breakdown of this tool. Before I started spending that kind of money I would think about possibly replacing it. If I have helped you would you please rate my response accordingly and Thank you.
Posted on May 27, 2009
  • 33 Answers
SOURCE: DeWalt DW972 cordless drill has intermittent
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Posted on Dec 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Variable speed doesn't work on Milwaukee Magnum hammer drill
how new is the tool. Give me the serial number and I will come up with a solution, also what is the switch number you bought. Let me know.
Posted on Jan 02, 2010
Craftsman cordless 1/2 19.2 m#315114852 stopped no smell turnd variable speed b/f worked again 4 a week then stop ,opened up cleand plug on trigger down pushed tight still nothing
could be a faulty directional control switch
have an appliance shop check it out
motors seldom fail as the voltage is not exceptional to cause a burn out
Oct 19, 2015 | Craftsman Drills
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
I have craftsman angle drill #315.115760, it no longer has variable speed, only high speed as soon as you start the trigger. Do you know what would cause this problem?
the switch has become damaged. will need to be replaced or cleaned. masonry dust can get into the switch over time.
Nov 07, 2013 | Drills
Variable speed not working
The variable speed function is controlled by the switch. If you only have off and full on, the only fix is to replace the switch (Bosch Part Number 2607202013).
Mar 14, 2012 | Bosch 23618 18V Cordless Impactor...
Drill with variable speed not functionning
If the variable speed is not working the trigger mechanism is faulty.
Mar 12, 2012 | Drills
I purchased a varible speed controler to use on my 1/2 hp AC electric motor. I sure now that a got the wrong type (dc) not an AC type. It blow the fuse in the speed contol and made the motor buzz; wrong...
most drill presses use a capacitor start motor with internal switching . a variable speed control will not work most rely on step pulleys for speed control. possibly you could have blown your capacitor
Feb 08, 2011 | Craftsman Drills
How do I troubleshoot the switch for a variable speed drill.
You need an electric some meter that checks all electric problems
Jan 11, 2011 | Craftsman Drills
Looking for a supplier of the speed control part
The best bet is to go on to ebay and buy a used one or onto craigs list. Unfortunately when these tools get a few years old, for Sears [craftsman] for example it is 10 years. Joe
Mar 17, 2010 | Drills
Drills Logo
65 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
