Question about Frigidaire PLMV168 Microwave Oven
I came home from work and the microwave sounded like a fan was going. When you open the door the the fan goes off. When you close it again the fan goes on and none of the buttons work.When you press the exhaust button a stronger fan comes on but thats it. I have it taped open so the fan doesn't run.
  • Frigidaire Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
On many brands, there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
If this does not answer your inquiry, please reply back with your brand and full model number from the tag on or in the unit so we can help you.
Otherwise...
Posted on Jun 24, 2009
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
When we open the microwave door, the fan goes on. When we close the door, the fan goes off
The most likely cause is a defective door switch, that should be repaired for safety reasons.
Feb 16, 2011 | Sharp R-1610 Microwave Oven
Every time I open the door to the microwave, it goes on automatically. Even if I press the button on the door, the microwave goes on. Should I just buy a new one, or is it an easy fix?
most likely the door latch assembly and or the door switch has failed... there are approx. 3 micro switches located where the door closes... these switches all operate items such as the cooling fan,timer, clock assembly etc... sounds like one of these micr switches have failed and will require getting inside to exam with a meter and check contuinity on close and open when switch is open...good luck to you...
Jan 19, 2011 | GE Monogram ZE1660SA Microwave Oven
Our Panasonic NN-S763BF microwave turns on (light goes on, table turns and fan goes on) automatically when we open the door even though the clock is displayed. It works normally when the door is shut....
You have a faulty interlock switch (which the door operates).
This needs to be renewed by a qualified microwave service technician ASAP.
A potential hazard if not fixed immediately!
Oct 06, 2017 | Panasonic NN-S763BF Microwave Oven
Whirlpool Microwave after cooking fan on when door closed
Guess I'm an impatient person, took microwave to service center this morning. Hopefully, have it fixed by this afternoon. Thanks.
Jun 17, 2009 | Microwave Ovens
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
Frigidaire PLMV168 Microwave Oven Logo
109 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
