Question about Philips 42PFL3704D LCD TV
Reset phillips tv - Philips 42PFL3704D LCD TV
Phillips 32 PF5320/28 will not auto detect antenna stations. TV set on antenna, go through auto detect, nothing. Just another typical Phillips product?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sep 10, 2017 | Televison & Video
Phillips flat screen tv left half of screen is black right side is dim and flickering
Is your tv less than a year old? You need to call Phillips and see if it is covered under warranty. If that is not the case you need to get a few estimates. You want to know if it will be cheaper to repair or replace your tv set.
1 888-744-5477 Phillips customer service number
Aug 14, 2016 | Televison & Video
How do I reset my Phillips TV if it will not come on?
Try unplugging all your tvs from mains and keep unplugged for a few hours. try to plug back in and attempt to turn on. See if this trick works. Likely there could be some internal damage in power supply or it could be fuses.
Oct 03, 2014 | Philips TV Tuner Video Capture PCI Card -...
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
How to replace lamp
1. Turn the tv off and unplug it. 2. carefully access the back of the tv. 3. when facing the back of the tv on the lower left hand side there is a cover held on by two phillips screws remove this cover. 4. After cover is removed you can see the lamp which is also held in by two phillips screws, these screws only loosen and do not completely remove from the lamp. 5. after loosening the screws there is a handle in the center of the lamp, take the lamp by the handle and remove it from the tv. 6. reverse this process to install lamp.
I hope this helps you. After you replace your lamp make sure you reset the hours for your lamp. Press tv menu, select the setup menu, and then select the lamp reminder option to reset hours to zero.
Nov 17, 2010 | Mitsubishi WD-62528 62 in. LCD Television
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Problem with televisor phillips 27f8007583 chassis
Philips 27f8007583 how to reset auto programming
Dec 29, 2008 | Philips 24PT6341 24" TV
Phillips TV
What is the purpose for resetting the tv?
Aug 08, 2008 | Televison & Video
Phillips/magnavox smart series
I have a Smart Series 32" Phillips-Magnovox TV I bought april '99. Around July 4 weekend 2008 it decided it just does not want to come on any more! Was working just fine before that...I can not find my manual. Any suggestions?
Thanks,
cely
ceorunner@aol.com
Mar 04, 2008 | Philips Magnavox 27MS343S 27" TV
Philips 42PFL3704D LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
