Question about Danby Washing Machines
Why does my machine keeps filling up with water but not washing
  • 1028 Answers
SOURCE: Our washing machine keeps filling
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Posted on Apr 27, 2008
SOURCE: Washing Machine keeps filling with water
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Posted on Aug 13, 2008
  • 958 Answers
SOURCE: fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
  • 163 Answers
SOURCE: my washing machine keeps running water to fill up,
sounds like you have a siphon problem.check your drain hose and make sure it is up at least to the head of machine and make sure it is not a tight fit.
Posted on Mar 20, 2009
canbruce75
  • 1776 Answers
SOURCE: my washing machine will not hold water
Make sure your drain is at the proper height. Here is a photo for reference. The water draining straight thru can be caused by this. If this is not the problem, please let me know. Hope this helped and best wishes.
Posted on Sep 13, 2009
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
My whirlpool front load keeps cycling without the water filling.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Whirlpool washer keeps filling beyond fill and does not agitate - timer has been replaced
More then likely the soleniod valve has dirt stuck undr the seat and it cannot close....
When a washer just keeps on filling with water it is
Kind of the opposite of this problem that I wrote about in these tips...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 19, 2010 | Whirlpool Washing Machines
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Washing Machines Logo
29 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
