Question about Western Digital Caviar WD2500BB 250 GB Hard Drive
How do you turn a hard drive from master to slave
  • 372 Answers
To set a IDE Hard Drive as Slave you would need to change the jumpers/pins on the back of the drive
See this link Here
Posted on Feb 08, 2015
4 Suggested Answers
  • 9 Answers
SOURCE: need master slave configuration
First set the jumper pin for master or slave configuration as provided in the cover of the hard disk.
Posted on Mar 20, 2009
darshanks
  • 40 Answers
SOURCE: 80 GB WD hard drive being used as master with
u ll have a jumper which is located at the back where u hv ur power supply pin.. there u ll hv one pin with 6 needles on which a plastic jumper ll be there only on 2 of the six needles. that plastic jumper may be in slave mode do remove the jumper and place it in master mode.....
thnkyou
Posted on Jun 29, 2009
virtual_a
  • 531 Answers
SOURCE: what kind of master/slave used
Hi
The WD schematic diagrams here should tell you everything you need to know:
http://www.wdc.com/en/library/eide/2579-001037.pdf
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Posted on Sep 06, 2011
How to make a master fujitsu mvh2080ah? Which jumper do I have to use to render the 2.5" hard drive master? Thanks a lot, Mustapha
Fujitsu might be different have a look on top of the hard drive this is if your hard drive is IDE 40 pin flat bibbon type leads
if its a SATA hard drive the larger drive takes the master
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
hope thie helps
Jul 20, 2012 | Fujitsu Computers & Internet
Select as master
slave :::':
Nov 14, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
slave :::':
Oct 03, 2011 | Dell Computers & Internet
Installation of the drive and setting of jumpper to make it either as a master or slave
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 27, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
???????????????? slave? :::':
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
Need jumper settings for slave drive WD1600JS
slave :::':
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD1600JS...
I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
Oct 04, 2009 | Computers & Internet
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Western Digital Caviar WD2500BB 250 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
