Question about Panasonic Workio DP-3520 Copier
Error e04-01 dp-2500 - Panasonic Workio DP-3520 Copier
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Service mode F9/ram initialize/fuser reset/reset power
Posted on Oct 15, 2014
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Panasonic DP 2500 paper tray error
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 22, 2008
  • 59 Answers
SOURCE: WORKiO DP 2500 everything is working properly no
hi just cheq tha scaner lamp is glowing if glowing may you have problem in charge unit or charge crona
thanks
Posted on May 15, 2010
How does this proplem occur? panasonic dp 2500 error e04-01
This error comes in fuser unit. the temperature is to low. Check the heater lamp, thermoswitch, thermistor and HTC board. Sometimes draping electricity voltage can cause of low temperature.
Mar 08, 2011 | Panasonic Workio DP-2000P Copier
Workio dp 2500 everything is working properly no image on the drum the machine does not report any error
thanks
May 13, 2010 | Panasonic Workio DP-2000P Copier
WORKiO DP 2500 everything is working properly no image on the drum the machine does not report any error
yep!
For dp-2500 the common and usual problem is light or no image on print
and the common cause is the contact plate between drum and magroller. there must have a proper contact through that plate.
sometimes we also encounter the contact spring(3) of hvps going to process unit - misaligned position.
you may also check the tension spring of the drum (located inside the drum) if it has proper contact to the shaft.
... pls inform me if this still isn't helpful.
Mar 22, 2010 | Panasonic Workio DP-2000P Copier
Thanks, Joe
Nov 21, 2008 | Panasonic Workio DP-2330 Printer
Service Manual Download -> Exchange Drum of DP-2500
For the service manual of a Panasonic DP-2500, pls try here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Panasonic Workio DP-2500E Copier
Error E01-22 - Check Printer on my DP-2500
"E1-22" 5th & 6th mirror assy. sensor problemMirrors are out of position, was someone cleaning the mirrors or touched for it for a reason??? if not the sensors are bad
Aug 28, 2008 | Panasonic Workio DP-2500E Copier
What can I do to fix it ?
What is the problem first? Then maybe a solution..
Jul 21, 2008 | Office Equipment & Supplies
Panasonic 2500
e4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Mar 31, 2008 | Panasonic Workio DP-2500E Copier
Fill
it is a fuser error
Mar 15, 2008 | Panasonic Workio DP-2330 Printer
Panasonic Workio DP-3520 Copier Logo
41 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
