Question about Jenn-Air Kitchen Ranges
Hood fan squeak - Jenn-Air Kitchen Ranges
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
#23350303200 Kenmore Elite Range hood - Range hood exhaust motor slows down
You have 2 windings in the motor that create a magnetic field. A winding is simply a coil of wire an they do not touch. when applying the voltage (turning on the fan) the windings create the mag. field causing the rotor to turn, which then of course turns the fan blade. When these windings get weak it causes them to heat up due to the resistance in the circuit and you there for loose ur mag. field... Or if the rotor starts getting restricted it will also heat up the windings an cause the fan to stop.. Time for a new venta hood....
Dec 01, 2011 | Kitchen Ranges
The engine in my automatic '91 Integra intermittently makes a loud squeaking noise...it sounds to be coming from the left side of the car under the hood. It is not the fan/fan belt, as the noise...
are you sure its not your fan belts? because if fan belts are not turning, it means that the engine is off. check if the tension in your fan belts are still ok. if not, have it re tensioned. if noise is still present, have it changed.
Aug 11, 2011 | Acura Integra Cars & Trucks
1996 Oldsmobile Bravada squeak under the hood
tension pulley maybe bad or belt may need to be adjusted
Dec 16, 2008 | 1996 Oldsmobile Bravada
Fan belt engine trouble
faulty water pump grinds and squeaks
stuck thermostat
cooling fan /slipping clutch =spinning to slow or faulty relay
oily fluid .spray
..oil and coolants mix
could have blown a head gasket by now
Apr 11, 2017 | 2006 Hummer H3
Loud squeak when engine is on.
Is it a squeak or a howell thats the real question here because it could be the oil trap which is about $140 and is attached to the bottom of the filter housing not to hard to do if you have worked on this type of car befor. And has the car died yet.
Nov 20, 2008 | 2005 Volvo S40
2008 Silverado 10,000 miles. 2wd has squeak
it may be the fan belt. The belt may need tightend or need a new one.
Jun 06, 2008 | 2008 Chevrolet Silverado 1500 2WD
Kitchen Ranges Logo
57 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
