Question about Electric Mobility Health & Beauty
Liteway golden tech scooter discontinued model can I still get battery and charger replacements ?
Discontinued model needs new battery and charger where do I get such if even possible and if not possible what solution to this problem any sugestions thanks
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: I need to replace the
This scooter requires (2) 12 volt 15 Ah batteries. Typically you would open the case and replace the two batteries inside not the entire case and batteries.
Locate the screws that hold the case together and open it. Make a diagram of the how the batteries are connected. Obtain the new batteries locally or on-line, install and fully charge.
Hope this helps.
Posted on Apr 24, 2011
I,m told i need 2 batteries but i only have a black box type
Hello Val,
The battery pack is not broken out in any of your FACTORY technical publications... www.goldentech.com is PERFECTLY USELESS (only offers to direct you to "LOCAL DEALER"
They only call them Gel-cells.
Looking on AMAZON... opportunities abound...
(personally... there no way I'd buy from ANYTHING
Without taking to a HUMAN... on how to open that battery box)
The case seems to be an important part of your units portability...
So as to not compromise your MOBILITY...
I am SUGGESTING you should contact ...
(to not VOID WARRANTEES)
Golden Technologies
401 Bridge Street
Old Forge, Pa 18518
or CALL TOLL FREE
1-800-624-6374
or use the URL (link) below to go to
their web-site
Home Welcome To Golden Technologies
live chat (was dead&gone when I tried)
http://www.gruberpower.com/search/node/liteway%203/4
Aug 07, 2016 | Golden Technologies Liteway 3/4 Wheel...
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Mobility diagram
Hi, send me a picture of the case contectors and i 'll show you how to wire it up ?
Regards
www.gewizrepairs.com/fixya
Oct 31, 2013 | Golden Technologies Golden Liteway...
My scooter will not start. The headlight and horn work.
HI,
I AM A GOLDEN TECHNOLOGIES REPAIR TECH.
SEVERAL THINGS CAN BE THE PROBLEM:
1. BATTERY CHARGER CAN BE BAD
2. THROTTLE POT OR SPEED POT CAN BE BAD
3.IF THE FREE WHEEL LEVER IS NOT ENGAGED THE SCOOTER WON'T RUN
4. IF THE CHARGER CORD IS PLUGGED IN IT WON'T RUN
5. FINALLY IF ALL THOSE ITEMS ARE OK YOU HAVE A CONTROLLER PROBLEM, WHICH IS THE MOST LIKLEY PROBLEM...THATS COSTLY
YOU CAN GET HELP BY LOGGING ON TO GOLDEN TECHNOLOGIES.COM AND ENTERING YOUR AREA CODE TO GET LOCAL PROVIDERS TO HELP YOU. OR CALLING 1-800-624-6374
GOOD LUCK
TIM
Apr 27, 2011 | Golden Technologies Companion II Travel...
I need to replace the battery case for my Golden tech liteway scooter. Or i need to see a wiring diagram. Can you help?
Hope this helps.
Apr 24, 2011 | Golden Technologies Golden Liteway...
Need a battery charger
i would give these guys a call , they can assist you on getting the right battery charger for your particular model . just click the link i have provided
http://www.spinlife.com/Golden-Technologies-Companion-charger-Parts/spec.cfm?productID=82710
Jan 13, 2011 | Golden Technologies Companion II Travel...
Our Liteway scooter has been unused for a couple of years. We purchased a new battery and charged it up but it won't run. The freewheel device is in place and we've done all the troubleshooting we know per...
terry, did you replace both batteries? If you did check your wiring connections on the batteries. Make sure that the polarity of the wiring is correct( red to positive and black to negative) and if you replaced just one battery then you have to replace the other one also. Once you have 2 new batteries installed and have made sure the wiring is correct. Turn on the scooter and see if you still get the flashing lights look at your manual and see that the 3 flashes mean a short between the batteries and the motor. If you continue to get the error you will have to contact your local provider or a service company to check the scooter.. Hope this helps
Sep 28, 2010 | Golden Technologies Health & Beauty
I was going up steep hill and it shut off. Won't go on at all.
This is highly unusual, so I would like you to check a few things first:
Thermal overload. Most scooters when pressed too hard will overheat and trip the breaker. This is to protect the scooter. If this happens, you wait 5 minutes and reset the breaker.
Otherwise:
Reinstall the battery pack.
Turn on the unit.
Does an L.E.D. start flashing on the dashboard?
If so, what sequence?
If not, when was the last time the batteries were charged?
Fully charge the batteries.
If none of this helps, contact the dealer you purchased this from or Golden Technologies technical service department. 1-800-624-6374 Ext 501
Aug 08, 2010 | Golden Technologies Liteway 3/4 Wheel...
Can you replace a brocken axle shaft that goes into the scooter m
Hi. Why do you need to replace the motor? Very few motors completely burn out. Most suffer from stuck or worn brushes, and these can be fixed.
Some scooter companies will only supply the complete transaxle assembly, which makes it expensive.
What fault does you machine have, and how old is it?
Good luck. Neil.
Jul 11, 2010 | Golden Technologies Golden Liteway 3 Wheel...
Health & Beauty Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
