Question about Dell Inspiron M5030 Laptop
How do I connect my m3050 to my sony bravia bx33
How do I connect my dell inspiron 1520 to my sony bravia tv
Connect a VGA cable from the video port on your computer to the video port on the Sony Bravia.
Boot up the Dell Inspirion and hold down the Fn key and press the function key that has the monitor symbol to divert the video data to the laptop video port.
Power up the Bravia and Input button on the remote and select the PC input.
You may need to set the laptop video resolution to 1024 x 768 (a higher video resolution may not display on the Bravia).
Feb 02, 2012 | Sony Televison & Video
We have a Sony Bravia and we cannot figure out how
check your connections first, dont use these connections with many pins, make sure use of those coaxial cable connections. if you dont have an indication on tv. check your cable for cuttings between main conductor and outer screen. using a avo meter.
Jan 11, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Ghosting on hdmi channel on my sony bravia
With HDMI there should be no ghosting. And being a Sony Bravia it should be no ghosting. My 52" Sony is great.
You've got connection issues.
Nov 25, 2009 | Sony Televison & Video
Bravia 32'' hdtv says ''no signal'' when I connect my Sony vgn FW27OJ with 15 pin wire.
Connect the VGA cable to the external video port on the laptop, power up the Bravia first, switch the Bravia input to PC and then boot up the laptop. The Windows image etc will be automatically diverted to the Bravia.
Jul 05, 2009 | Sony BRAVIA Televison & Video
Connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
Apr 30, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How do I connect a desktop to a Sony Bravia LCD TV?
hi
u want a tv tuner contact ur pc customer care itself they will only provide  u..it will cost some
Feb 14, 2009 | Sony Bravia KDL-32N4000 32 in. HDTV LCD TV
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Dell Inspiron M5030 Laptop Logo
Alun Cox
