Question about Minka Aire (Ceiling Fan)
How do i reverse motor without remote - Minka Aire (Ceiling Fan)
How do I reverse blower motor on bobcat sb 240 snow blower attachment
if your skid steer doesnt have a reversing remote valve (contact bobcat some models can be retofitted in field), then the only way to reverse is to unhook the hoses from and to the drive motor and unscrew lines to put hoses reverse direction , becarefull there maybe some residual oil pressure still there if you really need to do this after reconnection to skidsteer and remote is activated then blower will run backwards
Feb 21, 2015 | Garden
Muskoka mfb28-2
There is a capacitor that is bad. The capacitor regulates the phase of an AC motor. It looks like a can shaped object.
Dec 12, 2013 | Garden
I have a A.O Smith 2 HP motor. Is there any way I
Sorry, but no. Reversible AC motors are very different. Without that design difference (which adds cost) you can't reverse it. Your label is telling you that you don't have the special kind of motor.
May 14, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
How can i switch my fan to reverse? Its a Hampton
There is usually a slide switch on the side below the motor.
I don't believe any of them reverse from the remote control.
Nov 26, 2009 | Hunter 52" Ceiling Fan With Light And...
I have a 95 model 25hp mariner when selecting neutral i can only do so by going to reverse first. Going from forward to neutral it still stays in forward gear.
hi disconnect the remote gear cable on the motor then try it if you can get all gears and neutral without going into reverse all is ok put the cable back and ajust it if it won't work the control box is worn hope this helps merlin v12
Aug 26, 2009 | Boating
How do I reverse the blades without a remote?
theres a black switch around the fan to change directions , thanks AJ
Jul 14, 2009 | Dryers
It will not go into reverse but will go into forward. what should i do first? 1986 mercury outboard
You did not tell us if you have a small outboard or if you have remote shift controls. If you do have remote shift controls you can try reversing the cable ends if it is a 2 cable system or disconnect the cable at the engine. By disconnecting the cable at the engine you isolate the problem to the motor. Then you can grab the shift lever manually at the motor and see if it will now go into reverse. Some remote levers lock out reverse if the choke is engaged or if you are new to this boat there may be a button to push on the throttle to allow reverse to engage.
May 17, 2009 | Boating
HOW TO CHANGE DIRECTIONS OF BLADES ON HAMPTON BAY MODEL #70226
There is a switch on the side of the fan motor housing. Slide it the opposite way to reverse it. Make sure you wait until the fan comes to a complete stop to do so. Never reverse it while it is running, you could overload the motor and ruin it.
I believe they don't put the reversing switch on any remotes for that very reason.
Sep 15, 2008 | Universal Remote Control Hampton Bay...
Ceiling fan
The reverse switch is always located on the fan housing itself.  You cannot reverse using the remote.  Look for a black slide switch, probably located on the top surface of the fan housing so you cannot see it easily without a ladder.
Dec 15, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Minka Aire (Ceiling Fan) Logo
41 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
