Question about Magellan GPS
"software version" "4.92" roadmate 3055 - Magellan GPS
"software version 4.92"
check their web site please, search for your model #
May 17, 2014 | Magellan Roadmate 3055 GPS Device
I need to get software for 5045 for Germany, where do I order and how do I install it?
magellan web site is a good place to look. you`ll probably have to purchase and download to your pc then hook your magellen to you pc. they have data cables for that that usually come with it. or get one on ebay. Magellen usually has an app you download to your pc and plug in your roadmate and it updates it and for an additional fee they sell you updated operating system of you gps.
Apr 23, 2014 | Magellan Roadmate 5045 3065 3055 3045-LM...
How to make Hardware reset of Magellan Roadmate 3055-MU?
need help hard resting minemagllan roadmate 3045-lm gps
Jun 07, 2012 | Magellan Roadmate 3055 GPS Device
Register Magellan RoadMate
Hello.
If you want to register your Magellan, You need to go to Megellan web site and create password.
Here is the link to copy and paste in your browser. http://www.magellangps.com/s.nl/sc.73/.f?login=T
Sep 29, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
How to set up Magellan Roadmate to Bus mode
If your unit is equipt for this feature, then here is the operation manual link to copy and paste and put in your browser to help you.
http://www.manualbuddy.com/1598/magellan-roadmate-5045-manual
Thanks Mike
Sep 22, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Magellan roadmate 3055 freezes?
Hello , let's try and tackle this: This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. Add a comment
Jun 17, 2011 | Magellan Roadmate 3055 GPS Device
How do i update my magellan 5045 roadmate? when
Download and install Magellan's content manager software. Your GPS unit should be recognized after installation.
http://tinyurl.com/4rmxv3t
Mar 07, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
GPS Logo
46 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
