Question about Coleman (100076) Compact Refrigerator
Why does my koolmate 36 does not get cold? - Coleman (100076) Compact Refrigerator
I have just bought xjr 1300 2009 what r the tyre pressures
We would advise that for your Yamaha XJR 1300 if on tyre sizes front 120/70 ?€" ZR17 58W TL (tubeless) and Rear 180/55 ?€" ZR17 73W TL the tyre pressures (set when tyres are cold) should be as follows:-
Front ?€" 36 psi (pounds per square inch)
Rear ?€" 36 psi (pounds per square inch)
Oct 04, 2016 | Yamaha XJR 1300 SP Motorcycles
Thomson 36 ml 01 H fault
Check for any loose solder terminals at its horizontal output, and main IC legs.
Aug 30, 2013 | Thomson Televison & Video
Tempra 36 luke warm
turn thermostat up, if that doesnt do it, replace therm.
Dec 20, 2012 | STIEBEL ELTRON TEMPRA 36 Tankless Water...
What's the cost to fix a cold solder joint? our tv picture will cut out and on/off red light blinks as well.
It depends on who looks at the set and what they find---36 inch set with soldering issues anything from 50 dollars on up..........
Dec 04, 2012 | Toshiba CZ36V51 36" TV
Igloo Koolmate model 1301405, I need power cord that you plug in your car cigarette lighter where can I find one to order. It doesn't list is at Igloo web site
Call their customer service. The number can be found on their website. They have it and it can be sent out, it just isn't listed on their website. I ordered mine a few months ago. It was a little more than I wanted to pay, but a small price for a working unit on a road trip!
Aug 23, 2010 | Coleman 5640B807 Compact Refrigerator
Food spoils quickly
Place thermometers in the freezer and refrigerator. Freezer should be around zero. Refrigerator 36-40. 36 is better. Adjust your cold control (thermostat) to obtain the temperatures. Check your condensing coils. Are they dirty? Check your door gaskets. Are they sealing properly? Check door alignment. Do they shut properly? Good luck.
Jul 13, 2009 | Refrigerators
Need to know the tire pressure for 01 XL1200C front and rear
Hi .... manual states 30 front & 36 rear, I find 36 front & 40 rear good for single & two up riding. Tyre pressures are measured when cold.
Dec 24, 2008 | 2004 Harley Davidson XL 1200 C Sportster...
Freezer temp 7-20, ref temp steady 35. Ice on return line
HI thanks for your question. the way that frost builds up on the return line is the freezer is running too long . you have the temp set at too cold a setting 34 deg is too cold. it should be 36. 37. other wise frost builds up.thanks the appliance doc. please rate my answer. thanks.
Aug 13, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Coleman (100076) Compact Refrigerator Logo
89 people viewed this question
Top Coleman Home Experts
Donni Steen
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
