Question about Garden
I have a powerkraft limited edition riding mower. Montgomery Wards serial# TMO-3250008. The blade came of while mowing and the bolt is gone. Does anyone know what size bolt It was?
2 Suggested Answers
wadembly
  • 489 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
Changing blades on 2008 mtd rideon mower,are they left hand thread or just incredibly tight.
to remove the bolt or nut turn it the same direction the blade turns when cutting. This way the bolt tightens itself as it mows not back out and slip.
Dec 15, 2016 | Mtd Garden
Need belt diagram for montgomery wards 2000 elite riding mower
mtd signature 2000 elite Also, make sure you push in the clutch/brake in order to create enough slack to get the belt on....Good luck!
Aug 20, 2014 | Garden
I can't get the deck to ride/cut evenley on my montgomery wards yard tractor
check your blades,Needs to be leveled , Possible bent deck.
Jun 19, 2014 | Briggs & Stratton Garden
Change blades on riding mower
Your owner's manual should give you full instructions on removing the mowing deck from your tractor....once it is off, should be a simple matter of turning the deck upright and removing the bolts which hold the blades to the spindles and replacing the blades..... ;-D
Jul 17, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Wards signature 2000 lawn tractor TMO-3396409 18/46 parts and belts.i need to know the lentgh or part no. Of the upper deck belt. Mark
i have a tmo3396409 mower I need a7 speed trans axle or a 25 and 31 tooth straight gears
Jun 21, 2010 | Garden
I need help with my wards riding mower it is a tmo-3100002 the rats ate the wires off it all the diagram i have dont show the wires very good i need HELP
You may wan't to price a new wiring harness,they are not that expensive and are not too hard to put in,the lay out of the plugs and their location will lead you to the connectors that they need to go to.
Mar 21, 2010 | Garden
Hi i have a montgomery wards riding mower 1990
I might know what the problem is, on those models there should be a ignition switch, or a killswitch under the seat of the mower. When the 2 people sat on it, it might have jarred or broke the switch. You might want to check it to see if thats your problem. I hope this might help.
Nov 02, 2009 | Garden
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
