Question about Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230
I have three wires on pump with three connectors new pump has fourconnectors
Its a 1.5 waterway pump just like old one only it has four connectors
    Top Expert:
  • Waterway Master
  • 6,465 Answers
Look on side of motor for diagram
Posted on May 25, 2016
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
TheSpaDoctor
  • 10 Answers
SOURCE: electrical connection to pump
can you photograph the new connections for me? if you look at the connections, the neutral normally has a solid link across it, the earth will be to the frame and the other two are the high and low speed live connections.
info@the-spa-doctor.co.uk
Posted on Mar 25, 2009
  • 3600 Answers
SOURCE: Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Posted on Jul 05, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
Coastsider
  • 331 Answers
SOURCE: can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Posted on Apr 14, 2010
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Waterway pump four wires res white black green which is ground old pump1.5 hp had three connectors plus screw ground new pump has four connectors plus screw ground
make sure new one is wired for 120 volt then the black goes to the L1 the white to L2 then the green to ground or case make sure to change brown and white to accomidate 120 volts
May 17, 2014 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
I just got a 2hp Waterway 48 hiflo pump. The discharge is facing up can it be rotated to the side or is it fixed?
There a four bolts that run through the motor into the wet end, or pump. Use a 1/4" nut driver and loosen the bolts until they are free of the wet end, then you can rotate the wet end so the discharge is face to the side. Tighten the bolts and your done.
Sep 07, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
Jul 05, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Electrical connection to pump
Mar 14, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Using 4 wire plug on 3 wire dryer
YES TAKE THE GROUND WIRE OF THE NEW PLUG AND CONNECT IT TO THE FRAME OF THE DRYER UNDER AN EXISTING SCREW OR USE A SELF TAPPING SCREW THE FOUR WIRE SYSTEM WAS PUT INTO THE CODE MOSTLY TO INSURE GOOD GROUNDING ON MOBILE HOMES AND THE METHOD WILL WOKE FINE AS I HAVE GIVEN YOU
Nov 16, 2008 | GE Dryers
Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230 Logo
59 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
