Question about JVC RX-8000V Receiver
Why auto mutingon display and have no sound - JVC RX-8000V Receiver
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
When i put the fm radio it display auto muting and doesnt have sound, this only happens with the radio because the dvd sounds ok
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
Aug 14, 2011 | JVC TH-M303 System
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
What does AA on the display screen mean? THis is on my display scrren, also when i get a call, an automated voice sounds saying"call from____"
I have an SCH-U450 and had the same annoying AA on my nice wallpaper picture.
Although it doesn't appear in the icon library, apparently, it's for Auto Answer. As soon as I turned that off, it went away.
In my phone to to, Menu > Settings & Tools > Call Settings > Answer Options, and make sure Auto w/ Handsfree checkbox is UNchecked (unless, of course, you want it on, in which case, I guess you're stuck with the AA in the middle of your nice wallpaper picture).
As for the audio announcement, mine was set when I got it to yell out the name of the contact for messages and calls. Try Menu > Settings & Tools > Sound Settings > Call Sounds > Call Alert, then choose Ring Only, or others as appropriate.
Feb 27, 2010 | Samsung SCH-U470 Juke Cellular Phone
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven control..do any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
Sound problem on Technika LCD19-907
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jun 19, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Nov 14, 2007 | Hitachi 53FDX01B 53" Rear Projection...
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
JVC RX-8000V Receiver Logo
21 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
