Question about Kenwood KM400 / KM410 Chef Classic Stand Mixer
How do you clean the dawn fraser juice master
What was valuable about the Rock Health mixer meetup?Need to emergency,suggest me please?
In cooking site mixer is a most useful things.Because of its reduce your valuable time and help for give you a best juice in a short time,Which is too much healthy for your body. you can know more if you visit this site... KitchenAid 6 QT Mixer
Oct 18, 2016 | Food Mixers
I need to find an electrician to recondition an old sunbeam mixmaster
Look in the phone book and find a local business that repairs small appliances, call them.
Oct 15, 2016 | Sunbeam Food Mixers
I have a kitchenaid stand mixer which kept slowing down and finally wont start at all.i replaced the bushes but still it wont start help!
Hi CHESTERMALPA, I hate it when that happens. It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature’s commutator. The concave contact face should be resting completely on the commutator. If you've turned it 90 degrees too much, it won’t' seat properly and the motor doesn’t get any juice.
Good luck, I hope this helps. Howard, Burke, VA\
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 05, 2009 | Food Mixers
Kitchen aid k45ss classic unscrewed black plastic screws and springs on housing and replaced and now it won't run
Hi, JDMCIN. I hate it when that happens. It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature’s commutator. The concave contact face should be resting completely on the commutator. If you've turned it 90 degrees too much, it won’t' seat properly and the motor doesn’t get any juice.
Nov 26, 2009 | KitchenAid K45SS Classic Stand Mixer
Took apart, pull magnets from sides, now the thing
ECARRERO2004 - Those 'magnets' you removed from the sides of your mixer are the electric motor brushes that provide power to the commutator/armature assembly so your motor runs. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the commutaor. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Nov 24, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
I did not receive a manual with my Mix Master model# 2349
If you go to www.apwagner.com you will get the story on Sunbeam and perhaps you may be able to get a manual. Please rate this answer,thanks.
Apr 11, 2009 | Sunbeam Heritage 2346 Stand Mixer
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Broken mix master
http://www.fixya.com/support/t636606-kitchenaid_ksm90_stand_mixer
Sep 11, 2008 | Food Mixers
Kenwood KM400 / KM410 Chef Classic Stand Mixer Logo
99 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
