Question about Maytag Portable Air Conditioner M6P09S2B
Caution light comes on and won't start - Maytag Portable Air Conditioner M6P09S2B
My caution light comes on after 10 min on the highway and 20 min in the city and it idles high and low at start up for 2 min until it warms then it idles fine when the caution light comes on it start to...
caution? what lamp, what does it say? exactly or the operator guide book state in the glove box?
what Civic, there are 3 that year,
Do you mean the CEL/SES check engine light.?
well pull the diagostic fuse to see the codes stored.
1,2,3,4? (lots of honda's ,see your here) and full docs,too.
did you do the 60k mile tune up yet(every 60k?) last one?
if not why not?
http://honda-tech.com/showthread.php?t=810101
Oct 06, 2013 | 2000 Honda Civic
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
My microwave won't heat anymore
CAUTION CAUTION CAUTION CAUTION CAUTION CAUTION
best not mess it is very dangerouse to mess with these things unless your a qualified engineer they are lethal things in the wrong hands CAUTION safer and better to bin and replace with a new one its cheaper as well
Aug 04, 2012 | GE Microwave Ovens
Signal light won't click off
The plastic canceling cam in the steering wheel, well, behind the wheel-you have to pull the steering wheel off to access it. It is probably broken. New ones are available at a parts store. Check a repair manual for caution notes and how to work in this area without activating the air bag. You have to take off the negative battery cable, and wait about 30 minutes before starting repairs around the air bag.
May 23, 2012 | 1998 Ford F150 Regular Cab
Won't start lights come on but engine won't do anything
There is a good chance that you have a blown fuse or that your starter is gone.
May 16, 2012 | 2004 Chevrolet Express
2000 s-10 4 cylinder oil filler cap won't come off.
Tap it with a wrench and then use a pair of pliers to twist but do not CRUSH DOWN on the cap itself, you are using it as leverage and not as a vise.
CAUTION, CAUTION, CAUTION
Use it as a Grip and not CRUSH THE CAP when you twist. If the plastic it brittle and it breaks, you may have to use a hammer and chisel and remember
LEFTY LOOSY, RIGHTY TIGHTY
GO COUNTER CLOCKWISE
May 26, 2011 | Chevrolet S 10 Cars & Trucks
94 vette won't start,bat good,have org. key,fuses ok,high beam light on lights off,lcd cluster won't light up?
Disconect the battery and ECM for FOUR DAYS then reconect the ECM and BATTERY. Let it sit for another four days without turning anything on. It should start but will run rough for about 200 miles as the ECM relearns the system. I had the same issue and that is what fixed it.
May 14, 2009 | 1994 Chevrolet Corvette
Heating & Cooling Logo
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
