Question about Maytag M6Y12F2A Air Conditioner
Maytag M6Y12F2A-E Power Cord does not work properly. When reset button is pushed nothing happens. If I hold it down for a few minutes the light flashes green. Unit does not come on. Please help me figure out what is wrong with unit. Can the power cord be replaced and if it can, where can I find the part.
22yooper
  • 828 Answers
SOURCE: Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Posted on Jun 08, 2008
22yooper
  • 828 Answers
SOURCE: the installation of a Maytag 6,000BTU Window Air Conditioner
Yes if it is heavy duty you can run the A/C on it. #12 wire is rated for 20 Amp service. Keep the length of the cord to a minimum. #14 wire is rated for 15 Amp service.
Posted on Jun 16, 2008
  • 121 Answers
SOURCE: Maytag A/C window unit
Check all of the connections at the outlet. If everything looks ok test the outlet that it is plugged into with a tester. They can be picked up at most stores for around 8 dollars. If you dont have a tester you can just plug in another device that you have into the outlet and see if it turns on. If everything checks out OK then there is an issue with the A/C unit. It could be alot of different things. My recommendation to you is if it is under warranty contact Maytag and send it in for service. If it is not under warranty you can either contact Maytag and send it in for service or you can call a local heating and cooling shop and see if they can service it for you. Keep me posted - Tech101
Posted on Jun 27, 2008
huuum
  • 750 Answers
SOURCE: control panel for Maytag M6Y12F2A-E
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said you can't find a ccontrol panel for Maytag M6Y12F2A-E online to purchase.
Go to repair clinic .com which is a sponsor of fiya.site
Please remember to leave solved rating before you go!
Thank you
Posted on Sep 29, 2008
  • 44 Answers
SOURCE: Maytag M6Y12F2A Window AC Unit
The capacitor should have a MFD (or UF)rating. As long as you match these numbers you can use any brand. Try searching these numbers not the model of the unit.
Posted on Aug 27, 2009
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
HP 1315 printer won't turn on
I have an HP printer too, but it's HP 2050. When i plug it in it usually makes a noise and then the power button blinks. To turn it on requires me to hold the power button down for a few seconds until the power button light stays on. If you haven't tried yet, try pushing down and hold and see if it turns on. Hope this helps :)
Apr 20, 2014 | HP Photosmart 8450 InkJet Printer
Hi I closed my laptop to put into hibernation mode and then noticed 2 days later that the power light was stuck on and not in hibernation. Upon opening the screen back up nothing happened. No lights, no...
You can try this: Shut the computer down and unplug the power cord from the computer. Remove the battery, then push and hold the power button and sing happy birthday to it. Or wait 15 seconds. Then plug the power cord back and try turning the system on. After it boots up, providing this fixes the problem, you may then replace the battery.
Hope this helps!
Feb 16, 2011 | Dell Studio 1737 Laptop
My laptop will not start after BIOS update pushed to me by HP Healthcheck.HP will not fix and expects me to replace PC or pay $399 for new board. Hewlett-Packard needs to be accountable for pushing a...
I had exactly the same problem last night. HP's 'Health Check' recommended that I flash the BIOS of our new HP Dv7-1175. Had the computer about 3 days, and was receiving some strange errors reporting unrecogized USB devices not recognized and a buggy USB driver. So, OK, Flash the BIOS.
Precisely the same thing occurred. The utility for flashing the BIOS ran, seemed to work, shut down the computer. Then nothing.
I restarted to a backlit screen, no POST or BOOT. Here's how I solved the problem (though I can't tell you why it worked, other than it obviously reset the CMOS).
1) Turned off the computer
2) Removed Battery and disconnected power cord.
3) Waited, pensively, for 5ish minutes (read several places to wait for 20 minutes; I didn't)
4) Plugged the power cord back in (I did NOT reinsert the battery)
5) Holding down the Insert/Scroll button, I held the power button down for 20-30 seconds. Nothing happened until I released the power button. When I released the power button (still holding the Insert/Scroll button depressed), the computer came up and Windows booted. Could not, at that point, get ESC pressed; wouldn't let me into the BIOS.
6) Restarted and prayed, came up normally; opened the BIOS by hitting ESC at the proper time, reset to defaults (just to be sure).
The computer has seemed to work operate normally since, though for the life of me, I can't tell you why this worked. I was, for the record, trying to press the Insert button, so if yours has these separated-- as my Toshiba does-- then I'd start with that.
Hope this helps someone.
Jun 01, 2010 | HP Pavilion dv9000z Notebook
I have a HP Pavilion a1140n. The computer froze and was turned off by holding down the power button, but it would not boot up. No light appears on the power button, and when it is pushed, the DVD drive...
hmmm strange first thing id try is resetting the bios it seems it has been effected . remove case remove battery leave off for 3 minutes and replace try then again, while u have the battery out hold the power button on , oh and make sure the power is plugged out, and yeap hold power button for 3 secounds just to drain last of power from power supply. hope this helps
Nov 29, 2009 | HP Pavilion a1140n (PX774AA) PC Desktop
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
I have a gas stove. The oven is digital. When I looked at the part where the clock is and the temperature is displayed it had a P then a backwards H and then 2 other letters I couldn't read. All of the...
The next thing I would try is to unplug the oven from power ( wait a few minutes) and then plug it back in.. Sometimes the control circuit gets corrupt and a power down/power up reset clears the problem.. Please let me know if after you try this and it works or doesn't.. Hope that helps..
Aug 29, 2008 | Maytag Kitchen Ranges
HPc6150 printer error
Hai
I Seems to be a hardware problem.Follow my troubleshooting steps.
STEP 1:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.(if it doesn't works goto step2)
STEP 2:
PARTIAL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
STEP 3:
SEMI_FULL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
STEP 4:
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
If they don't work, the printer needs to be serviced.Let me know the status.
Thanks
Riz
May 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Laptop
Try this,
Unplug the laptop, remove the battery from the underside (there should be a catch to push, and the battery will pop out). Then wait a few seconds and put the the power cord back in and the battery. Hold down the on button for a few seconds and boot it up.
May 22, 2008 | Computers & Internet
Maytag M6Y12F2A Air Conditioner Logo
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
