Question about Kenmore Sewing Machines
Won't make any stitch
Our sewing machine which has been used 'off and on' for a number of years has suddenly begin to give trouble. It began with several broken needles and then with the machine not sewing at all. I have tried many different types of needles -- doesn't make any difference. I thread the thing and it doesn't make one single stitch. After pushing itself through the fabric once or twice the needle comes up 'empty' (without having picked up the cotton from the bobbin). I've looked at things closely but I just can't figure out what/where the problem(s) might be. As I said, this sewing machine has served us well over the years 'without a hitch' -- now all has changed (with this sewing machine!) Do you know of anything I can try? Thank you!
  • Kenmore Master
  • 9,254 Answers
In all the years you've had it, have you cleaned and oiled it?
Posted on Apr 01, 2015
SOURCE: Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Posted on Nov 18, 2007
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Mongo32
  • 111 Answers
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Posted on Jun 11, 2009
  • 980 Answers
SOURCE: Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Posted on Jun 26, 2010
I'm having trouble starting the stitching on my bernina 765 when sewing a 1/4 inch seam. I am using the patchwork foot and have tried the differential feed option which doesn't seem to help
Guess I'm confused as I thought differential feed was available on a serger but this appears to be a sewing machine. If you are having trouble beginning stitching, try using a piece of scrap fabric as a starter piece. Just begin your stitch in the middle of the scrap of fabric and slip the quilt fabric up to the scrap's edge and continue stitching from the scrap onto the quilt fabric.
Stitch Starter Sewist Running Board
Jan 18, 2017 | Bernina Sewing Machines
I have used my machine for over five years, never had a problem until today, the arm wheel at the side is suddenly stiff to turn and its not sewing a zig zag I was doing.
Try unpluging it from the power. It may need to resent . Try a basic straght stitch and see what happens. Then go back to your Ziz zag stitch.
Mar 05, 2014 | Brother CS6000i Computerized Sewing...
Needle won't remain threaded
make sure the thread has long thread tails of 4 to 6 inches long
and have the thread tails pulled behind the needle before starting
to sew.
Jan 04, 2013 | Michley Lil Sew Mechanical Sewing Machine
Stitch length suddenly stops and only sews on @ 1 length regardless if set @ 5
Cas: I'm going to give you a link to a google ebook that talks about these issues. Unfortunately, it's only a preview but it does show a great trouble shooting chart and mentions consew machines..
http://books.google.com/books?id=GLadvNufjaUC&pg=SA4-PA1&lpg=SA4-PA1&dq=sewing+machine+repair&source=bl&ots=RL9-FxFV_Z&sig=ZxOm_8lMAbm6uIActH_GwiFwXug&hl=en&sa=X&ei=d3ZLUIbyKcX9iwLh24DIDg&ved=0CFoQ6AEwBw#v=onepage&q=sewing%20machine%20repair&f=false
Good luck
Aug 31, 2012 | Consew 199R-2A Sewing Machine
Screen won't show numbers on quantum 9910
it sounds like the computer part of the machine needs to be check at a sewing machine repair shop
Jan 20, 2012 | Singer Quantum 9910 Computerized Sewing...
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
My LS2125i will sew a straight stitch but when I turn it to a zigzag stitch it takes a couple of stitches, then all of a sudden the top thread on the spool holder goes... whirl and winds the thread around...
sounds like your thread is getting caught in the thread spool's thread keeper notch. Make sure you use the spool holder disk with the closest size to the spool of thread to help prevent that. This is pretty common with old fashioned spools like coats and clark spools.
My brother suggests that i make sure the spool unwinds in a certain direction. You might check your manual to be certain the thread is unwinding the correct way.
Good luck.
Dec 18, 2010 | Brother LS-2125 Mechanical Sewing Machine
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
