Question about Pool & Spa
What does jandy pool heater error code fl 6 mean?
3 Suggested Answers
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
john224
  • 1378 Answers
SOURCE: Jandy Lite 2 pool heater
Thank you for posting your question here on Fixya.com.
Page 34 and 35 of your manual, found here, describe FL0 as a flow issue most likely caused by dirty filters. Depending on the type of filter you have a good cleaning/backwash will usually remedy that. It is also possible the unit's pressure switch, which senses water flow and therefore reacts to dirty filters when present, may have failed, especially if you winterize the heater in a cold climate and leave water in the switch which can burst the diaphragm inside.
Start with cleaning the filter. If the heater still won't fire jump out the pressure switch while the pump is running to confirm the part is the problem. Assuming it is replacing it with a new pressure switch which should be under $75. The part number can be found in the rear of the manual.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 29, 2011
FL1 error
FL 1 normally means shorted temp sensor
Jul 18, 2014 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
Fl 6 error
signal to energize gas valve is not being sent by controller either bad board or shorted wire sending 24 volts to gas valve
Jun 04, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy R0317100 Gas Valve
make sure you have adequate gas pressure that is a safety so the heater will not self destruct must have 7.5 at least coming in check with the gas company to make sure you meter is big enough
Nov 15, 2013 | Jandy Laars Lite2 Lj 250,000 Btu Heater
WWW.JANDY-DOWNLOADS.COM
Make sure all the dust is off the fan definately and all other parts are cleaned.Leave unplugged for a few hours if you do not have a reset option to clear the error code
Jun 03, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lit 2 heater error fl 6
gas signal being sent to gas valve not by controller either stuck gas valve or bad control board
Apr 14, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
I am getting an FL 2 error code on my jandy lite2. I changed the flame sensor and still get same error message
Look at the list of codes inside the cover of the heater. Your owners manual should have a complete remede for all codes.
May 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
FL 4 code Hot surface igniter problem on Jandy Lite 2
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jul 29, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool & Spa Logo
73 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
