Question about Sony Televison & Video
Clean a Sony rm-g005 - Sony Televison & Video
Why can't i Access changing Chanel up or down on my sony rm- yd028 remote control?
if u can take your remote apart on the circuit board take an eraser from a pencil and clean the pads they will be dark in color then put back together try it
Sep 21, 2014 | Sony RM-YD024 REMOTE CONTROL PART...
RM-VZ320 won't even turn on my player, help?
depending on age you might have to take apart not hard and clean the key pad where they make contack with bard with pencial erraasor or rubbing alcohol and a cotton swab to clean contacts good luck
May 03, 2014 | Sony RM-VZ320 Remote Control
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
I need to separate the covers on a Sony TV Remote Control but there are no screws holding the covers together. Model no. RM-ED005 (R) Can you help?
At the bottom of your Sony RM--ED005 Remote control you'll see 2 small rectangular holes. I used two small screwdrivers, one to create a gap the other to prise the unit apart, when u are able to get your fingers in gently separate both parts from bottom to top.
You'll notice where the rubber pads meet the contacts there is 'condensation' this is what causes some of your remote buttons to fail.
Simply wipe away with a clean damp cloth, dry off, clip the remote together again and you basically have a new remote control.
May 31, 2011 | Sony RM-V310 Remote Control
How to fix a Sony Tv RM-YD026 remote after getting milk in the buttons
take batterys out then take out the little screws in battery compartment pry open the two halfs clean the board and buttons and let dry dont wipe the carbon off it is the main part of the switch for the buttons just clean with water and let dry
Oct 20, 2009 | Sony RM-YD023 Remote Control
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Nov 19, 2008 | Sony RM-AAP001 Remote Control
Televison & Video Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
