Question about Plumbing
Can't attach hose from Hitachi PAF-820p to faucet
2 Suggested Answers
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
Water coming through at trickle
Although you have not shared the make, model, and year, I will give it a try anyway.
Start by turning off the water at the faucets for the washer.
Then unhook the hose ( or both of them) and attach a garden hose to the faucet, and run the hose outside, or if that is not possible, run the hose to a sink or a shower or a tub, for the drain.
Turn on the water faucet and see if you get good pressure through the water hose.
If you do, then examine the black hoses from the faucets to the washer.
Often these have a tiny wire mesh filters inside the end or ends of them to filter the incoming water.
These can plug up with sediment, and you will need to clean them.
If they are clear, then examine the attachment on the back of the washer, where the hoses go.
These can also have tiny wire mesh filters inside, that can plug up with sediment.
Those screens can be removed and cleaned.
God bless your efforts.
Dec 19, 2016 | Washing Machines
How do I connect the sprayer hose on single sprayer faucet ,peerless style, the pin wont go in?
What is the model number of the faucet? There was no attached pictures to this submission.
Jun 14, 2014 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Hitachi paf 1220p washing machine
Uneven Load or try check it out for something stuck inside washer drum or tub or inside pump or loose or broken parts
May 21, 2014 | Washing Machines
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
I need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you
Reply to rutledge5135 on Apr 11, 2011
(i need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you)...
The 'S' is for 'Spray' which happens at the beginning of the Spin Cycle...it then goes on to rinse etc.
regards, avery.phill@gmail.com
Apr 11, 2011 | Hoover Washing Machines
Online repair manual for hitachi washing machine moel PAF-1220P
machine does not want to turn during wash cycle and smells like it's burning out motor... drain and spin still work fine.. any idea what is going on? thanks..
Sep 14, 2010 | Washing Machines
Grohe ladylux plus kitchen faucet leaks from multiple points along metal pull out hose attached to faucet head. Is this fixed by replacement of same hose? How do I replace the hose?
Feb 23, 2010 | Grohe Plumbing
I cannot get the attachment on my appt. size
The hose fitting goes onto an adapter that screws on to your faucet. You have to have the piece on your faucet for it to work. As best I can recall, once both pieces are in place, you pull down on the locking collar on the hose, put it on the faucet and relaese.
Best regards, --W/D-- please feel free to rate this solution..thanx!
Aug 01, 2009 | Kenmore Dishwashers
Faucet Attachment Leaks
The o rings need to be replaced and plumbers lube added on the interior of the connection point.
May 15, 2007 | Kenmore 17259 Free-standing Dishwasher
Plumbing Logo
52 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
