Question about Homedics Digital Scale
Sc 405 calibration - Homedics Digital Scale
Replaced batteries and scale does not register weight, but just races through numbers and then "Err."
I have same problem with my scale. New batteries work for a few days. I'm throwing this thing out.
Oct 09, 2015 | Homedics SC-405 Glass Digital Scale Silver
I changed the batter in my homedics scale model #sc-535 1606 and noe it does not work
Open it again and make sure the battery is in the correct angle..... I have made this mistake from time to time
Sep 12, 2010 | Homedics SC-405 Digital Bath Scale
Cant Calibrate the Mp4 mbeat screen
press the reset button(pinhole)at the right side using a pin
Jan 08, 2010 | Digital Mind Corporation iQ Sound...
Customer has an Sc-405 code. They reset it by turning off machine then on. The machine only works for part of day then go's back into sc-405 code again.
that is a transfer belt error. transfer belt not moving away from the drum during ID sensor pattern check.possible main motor/ drive malfunction, trans. belt position sensor problem.
Nov 05, 2009 | Ricoh Aficio 450 Copier
Scale wont work
Sounds like a warranty issue. I would try to return to place of purchase if not here is web address on manufactures site with instructions on warranty.
http://www.homedics.com/products/warranty-returns
Nov 25, 2008 | Homedics SC-405 Digital Bath Scale
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Homedics Digital Scale Logo
259 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
