Question about Health & Beauty
What is celituis
Swelling of legs, and legs turning red What causes this
My leg have felt as though thing Pulsating thetththere is a pulsating feel is soing as though sommethis going upmand down my leg Insometimes feel this in my arm. What is the answer please?
hi pamela.
Throbbing from vascular origin
A vein can produce this sensation because of the increased blood flow to a particular area due to physical activity - this can happened when you jog in the morning or after bodybuilding exercise or any other physical activity. When somebody tackles you during a football game and traumatizes your leg, the swelling can push on the vessels and this can produce a throbbing sensation. A trauma can also produce an abnormal communication between an artery and vein - this is called AV fistula.
Usually throbbing from vascular origin is not a reason to worry. You may visit a general practitioner who will probably examine the blood flow and may even order a test to look at your vessels.
Rarely the cause of throbbing is aneurism which produces a wide pulsatile area - aneurisms are often treated surgically.
  • It is useful to know that common conditions such as deep vein thrombosis, blood clots or peripheral artery disease usually do NOT present with throbbing sensation but usually present with pain and swelling.
Throbbing caused by muscle twitching
Turn off the lights, sit on a chair and use a direct light from a lamp and try to make the light beam horizontal so you can see the throbbing area clearly.
If you see tiny twitches you should know that your throbbing sensation is produced by your muscles.
Conditions causing muscle twitching
Although muscle twitches are often idiopathic or as a result of muscle hyperactivity or hyperexcitability because you had too much coffee or you had a heavy exercise earlier, muscle twitches can be a symptom of a serious medical conditions.
B12 deficiency. This is found especially in alcoholics or vegetarians. Muscle twitching is not an early symptom, usually B12 deficiency presents with anemia and decreased or altered sensation.
Multiple Sclerosis. Usually presents with pain behind one eye. Muscle twitching is a common symptom.
infection and Amyotophic Lateral Sclerosis also known to cause muscle twitches. It is advisable to see a neurologist for further evaluation, the neurologist is most likely to order MRI and blood test
read up more at this link.
https://www.steadyhealth.com/medical-answers/causes-of-throbbing-or-pulsing-sensation-in-arms-or-legs
Understanding Symptoms of Aneurysm
https://www.steadyhealth.com/topics/strange-throbbing-pulsing-in-my-thigh-just-above-knee?page=2
what is the cause of Pulsating in my leg Google Search
Dec 12, 2017 | Cars & Trucks
How do I stop my ankles and feet to swelling after being sun burnt
Hello Anne.
Since this is a Q & A about cars and trucks,,, I will venture off topic..
This is serious and therefore should be evaluated by a physician. When you go to your doctor's appointment, be prepared to discuss the following possibilities. If the ankle swelling started just after the sunburn, it may be due to an inflammatory reaction as the skin tries to heal. A sunburn is a first degree burn but it still causes local inflammation and pain. As the body mounts an inflammatory response, the capillaries in the area dilate and become leaky. This process can cause localized edema and swelling, which usually resolves on its own over time. However, not every sunburn causes this reaction, so if yours is severe, you should see a physician. The reason you get extreme pain when you stand still is because the blood is pooling in your lower legs causing the swelling to increase. It is so painful cause the tissues are ripping apart to create room for the 'blood pooling' or tissue swelling. The most sensitive areas are the shins cause the tissue is tightly attached to the bone. That is why when you sit down or lay down it subsides or goes away. The body is not "upright" causing gravity to pool the blood in your lower legs ankles and feet can also be due to lymphedema. Lymph fluid travels up through vessel and is filtered through the lymph nodes of the body. Any issue with the lymph nodes or vessels in your leg can cause the fluid to pool in lower areas of the leg. If you have ever had lymph nodes in your abdomen, pelvis, or legs removed or irradiated, you should see a doctor very soon. Another possible cause of your problem, is your body retaining too much fluid overall, which can be manifested as swollen ankles and feet. This condition, called pitting edema, can affect people who have problems with their heart, liver, or other body systems. When fluid builds up in the legs, it can also build up in the lungs and other critical organs, so it is important to have this issue evaluated immediately. I strongly recommend that you make an appointment to see your primary care doctor ASAP!!, and he or she can refer you to a specialist if this becomes necessary.
Jun 16, 2017 | Cars & Trucks
I want to no what causes swollen feet
poor blood circulation, weight problem,
talk with your doctor as there can be other more serious concerns involved and fixya site is not a medical site
Apr 22, 2017 | Televison & Video
My left leg from knee to toes swells daily at least an inch. I sleep it goes to normal
Swelling of the leg may involve a noticeable distension of the shin or calf, ankles, feet or toes. Foot swelling may be a common occurrence which most of us will experience at some point in life after a long day of standing or sitting but may also be an indication of a more serious pathology as in certain cardiovascular disorders.
Recurrent or persistent swelling of the feet should be investigated by a medical practitioner especially if you have a history of cardiovascular disease or have noticed a change in color, sensation or mobility of the leg, foot or toe.
Blood rich in oxygen and nutrients flows through the arteries to the target area. Blood carrying deoxygenated blood returns to the heart via the veins where it is quickly routed to the lungs to be replenished with oxygen.
Blood flowing to the leg has to return to the heart through a group of veins with intermittent valves located throughout the course of the vein. This venous blood (blood in the veins that is returning to the heart) has to flow against gravity and since the pressure is usually lower at the feet, other muscles of the leg assist with 'pumping' this blood back to the heart. This muscle pump is most active when we are walking and least when we are standing stationary or sitting. Blood travels short distances up the vein and backflow of blood is prevented by a series of valves in these veins.
Working alongside the blood vessels are the lymphatic vessels which return lymphatic fluid (lymph) back up the body to empty into the blood system.
Swelling of the leg usually occurs as a result of an inadequate flow of blood or lymphatic fluid back up to the torso of the body. However other localized causes may further contribute to swollen feet, ankles or toes.
Apr 20, 2017 | Knee Health & Beauty
Does vascard cause constipation?
Yes it can be a side effect.
What are the possible side effects of Adco-Vascard? All medicines may cause side effects, but many people have no, or minor, side effects. Check with your doctor if any of these most COMMON side effects persist or become bothersome: Constipation; cough; dizziness; flushing; giddiness; headache; heat sensation; heartburn; light-headedness; muscle cramps; nausea; nervousness; weakness. Seek medical attention right away if any of these SEVERE side effects occur: Severe allergic reactions (rash; hives; itching; difficulty breathing; tightness in the chest; swelling of the mouth, face, lips, or tongue; unusual hoarseness); fainting; fever, chills, or persistent sore throat; mental or mood changes; red, swollen, blistered, or peeling skin; severe or persistent dizziness or light-headedness; shortness of breath; slow, fast, or irregular heartbeat; sudden, unusual weight gain; swelling of the arms or legs; symptoms of heart attack (eg, chest, jaw, or left arm pain; numbness in an arm or leg; sudden, severe headache or vomiting); tender, bleeding, or swollen gums; tremors; unusual bruising or bleeding; unusual tiredness or weakness; vision problems; wheezing; worsening chest pain (eg, longer, more often, more severe); yellowing of the skin or eyes.
Read more: http://www.ndrugs.com/?s=adco-vascard&t=side effects#ixzz4TVDvXhTf
Adco vascard Side effects
Dec 21, 2016 | Health & Beauty
What is the somtoms of foot infection
Pain and swelling that occur without an injury and with redness, red streaking,tenderness, heat, fever, or pus may be caused by an infection. Infections can occur without a known injury to the affected area. Pain, swelling, redness, and warmth that develop suddenly in a big toe joint may be caused by gout.20 Nov 2015
Inflammation or Infection of a Toe, Foot, or Ankle - WebMD
What is the somtoms of foot infection Google Search
Dec 19, 2016 | Computers & Internet
My lower leg was run over by a car, told no broken bones ,4 days later having extreme pain, burning, and blisters around ankle, with redness and hot touch, numb toes , now pain back of my knee.
The compression of the muscle has caused "compartment syndrome" In other words the swelling is causing damage and you need to seek medical attention right now if you want to save that leg.
May 24, 2015 | Health & Beauty
Mayoclinic com
With any post op there is the recovery stage, the question is are you sticking to the recovery plan as in not putting unnecessary pressure on it? Also your age will also play a role in your recovery. If redness and sensitivity to the lower leg is being experienced it could be a sign of an infection developing or poor circulation to DVT...Deep Vein Thrombosis. Either way my advice to you is to consult with your octor as soon as possible as DVT can kill you.
Oct 22, 2013 | Health & Beauty
3 Small Blisters and swelling of leg could this be Bite or Sting?
Go to the ER, it sounds like a snake bite.
May 04, 2010 | Yahoo Mail
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
