Computer speaker creative brand left speaker not working
I have creative A60 2.0 speakers plugged in to PC but sound only coming out from left speaker
The plug going into the PC is a stereo plug - it has a section for right, left and ground (return). If it's not plugged in all the way or the mating connector is faulty, you will have the symptom you describe.
Phone connector audio
Feb 12, 2015 | Creative A60 2.0 Speakers
Creative A60 speakers plugged into PC, sound only coming from left speaker, they both work ok with mobile phone etc
Lower the volume a little then unplug the speakers and touch the blank parts from the plug. Listen it both speakers give a hum. If so, you have to look in the computer. First check settings like volume and balance, then check you did plug in correct and if it is still only left, perhaps you have to replace the sound card. (or plug one in)
Feb 12, 2015 | Creative A60 2.0 Speaker System
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
I have creative 2.1 channel with sub woofer and 2 speakers (left&right) all of sudden my right speaker is not working left only working then I pluggeg right speaker to left speaker jack in sub...
I have a similar reoccuring problem with the left channel on my speakers. All of a sudden, while playing music or whatever, the left channel jusr dies. Turning the system off and then on again from the conrol unit does not remedy the situation. By chance, I discovered a workaround to get the left channel working again: Push the main power switch of the subwoofer until it almost switches off and then release it so that the power is never actually switched off. Now a click is heard in the system and the left channel comes alive again. This is quite annoying and seems to have something to do with switches in the subwoofer. Low quality components may have been used. I 've been thinking of getting another 2.1 system, but it's not easy to find one... Maybe I should open the subwoofer box and go through the switches and possibly hardwire some connections...
Jun 27, 2010 | Creative Labs MegaWorks THX 250D Computer...
Speakers wont work without installation cd
Left click on the start button and right click on My Computer.
Left click on Properties.
Left click on the Hardware tab and select Device Manager
You should have at least one device that says unknown..
If so, you will need to locate and install the correct sound drivers.
If the sound card came with your PC and it is a name brand like IBM or Dell, you should be able to find the drivers on their web site.
Aug 09, 2009 | Creative Labs Sound Blaster Live! 5.1...
2.1 creative speakers.
Speakers need to be used much often.If they are left without using they might get affected with dust and charge storage.It happens with generally every brand.
The solution could be either servicing it or generally using it very regularly.
Sep 07, 2008 | Creative Labs SBS 330 Computer Speakers
I have a creative 4.1 Speaker system but only Front speaker seems working???????????????
I have 4.1 creative speaker but only front 2 speaker will work
so i have connected convertor ie,2 output and 1 input then i connected to the green port so all the speaker are working.
Gowrish
Jun 15, 2008 | Creative Labs FourPointSurround FPS1800...
I need help
This is more a computer problem
Dig out the computer utilities disk and reinstall the sound card software.
or tyr to down load the sofware from the computer website.
Dec 27, 2007 | Creative Labs I-Trigue 2.1 3300 Computer...
A mess!
pls check your audio cable conection. bye
Sep 11, 2007 | Creative Labs Gigaworks S750 Computer...
26 people viewed this question
 Grubhead
Grubhead
