M8000 Do not power up
    Master:
  • 568 Answers
1) Check if the power cord is working properly.
2) If you can open the desktop check the power supply is working properly
the fan of power supply must turn on when you do this
3) if the power supply does not turn on the power supply is faulty.
40 If it turns on then there is problem with motherboard
Posted on Feb 02, 2016
I get no signal on my lcd when I start my m8000 hp pc desktop
There is no communication to the video card. Try checking cable. Reconnect. Make sure monitor is set to correct input, like VGA, DVI, or HDMI. Reseat the video card, and if still nothing, test with another video card.
Oct 04, 2012 | HP (D7580-60003) Motherboard
Hi. Have just turned on my HP Pavillion m8000 and the screen and it does nothing. The screen is getting no signal and even though the computer is on, it isn't starting up as usual. Help!!! I've checked all...
hi
it could be that your power supply (from tower) is not working -- does the fan blow out air ?
if not replace the power supply. If the power supply is on but no video on screen showing , it could be your mainboard inside the tower, thats if no noise is coming from the tower.
what were the circumstances when you worked on he computer ? was it plugged in overnight while running or was the power cord attached to tower while plugged into wall ? if so, it mnay have experienced a power surge and blew the mainboard.. too much current going to tower could blow the power supply, causing the mainboard to have received excess current
go to this link and rewview some infromation about your PC issue(s)
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=3328509&taskId=110
let me know what lse i can do -- i await your reply to some of the questions above
regards.
Dec 16, 2010 | HP Computers & Internet
Vista 32 bit or vista 64 bit
It looks like both of them will take a 64 bit operating system. You can't mess it up...if your computer is not compatible, it won't install.
If you don't have an operating system, I highly recommend Windows 7 over Vista. It is way better on resources and does a lot more with less memory. If you install Windows 7 -64 bit, you would be VERY happy with your system. It is possible to do a complete install without a keycode to see if you like it. Just hit next where it asks for the keycode and it will install, and it will give you 30 days to put a keycode in and activate it. That way you can get a disk, usually for about $5 or $10, (without a product key) (oh, and not from a store) and install it, you just won't be able to activate it...that way you can see what you like first.
Jun 16, 2010 | Compaq Presario SR5710Y PC Desktop
Hp media center m8000 was freezing so did a manual reboot, now it will not turn on
Try unplugging it and plugging it back in. If then you get no power try plugging it into the wall directly and check the power cord unplug it and plug it back in (From the back of the PC). When you press the power button put your ear to the PC and listen for a metallic click. Most PC's use a small micro switch to tun the power on and off but they do make a small noise if you listen.
If all this does not work the power supply is probably bad. If it is under warranty then send it in. If it is not under warranty you can replace it yourself all you need is a half hour and screw driver. From the picture above it looks like a regular tower so any ATX power supply will do.
But if you are not the get your hands dirty type any pc tech place can replace it for you and should only charge you $40 for labor plus $20 to $40 for the Power supply itself. By the way when shopping for a power supply you do not need that 1000w with the flashing neon lights. Get one that is around 700w look at the fan I personally would spend the extra money to get one with a large 4 inch fan with lots of air flow money worth spent in my book. The large fan can get more air flow for a cooler pc and since the fins are larger it can do it with less RPMs so you have a quiet little box in your corner.
Hope this was helpful
Sep 14, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
HP Media Center M8000. Network card bad, must replace motherboard
hello Friend,
here is the solution.
Buy New good Network Card Like D-Link or other cost about (10$-15$) install it on pci slot.then install drivers.so now u r system with new working Network Card.
if helps Rate the solution
Jul 02, 2009 | HP (D7580-60003) Motherboard
Blank screen; Unresponsive computer, & three beeps in succession
2 short beeps and 1 long beep (repeats 5 times) = Unable to initialize video or video card required but not installed. Sounds like the card may have gone down
Jun 19, 2009 | Intel Desktop Board D845GLVA...
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
We have a hp m8000 pavillion with a 17 " monitor purshased 2007. we bought a hannspree 22" lcd widescreen a couple of days ago. when we plug it in its say no signal. however when we plug it into our lap...
that happened to me. I felt stupid when I discovered what i did wrong. I attached the monitor cable to the connector at the top of the back of the computer(where it is supposed to attach, right?) - but, there was another connector for the monitor at the bottom of the computer which had been a special "card" add on. the monitor jack at the top did come with a plastic covering which meant not to use it. i thought the covering was just a protector, i didn't know. live and learn i guess.
Dec 26, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
