Why is the refrigerator side of my Whirlpool side by side (model # WSF26C3EX01) freezing all foods even down in the produce drawers. I gradually moved temp up to stop the food from freezing - now maxed out the temperature gauge control and it is still freezing. Freezer works fine. Sometimes the ice maker will stop working. Ice cream in the freezer is fine.
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor. This is where the cool air comes out into the fridge section. On this model it is a fairly common problem and comes a whole assembly. The part # is WR49X10091 and will cost anywhere from $100 to $122. Knowing this model I would bet this is your problem. If the damper is bad and stuck open cold air will just keep blowing in. It is suppose to open and close based on the temp setting. Let me know if you have any other questions.
SOURCE: Freezer and Refrigerator section stopped working
check your drain line and check defrost system, defrost thermostat, heater, and timer
SOURCE: Ice maker will not work
There's no ice
If your ice maker has stopped producing ice completely, check these, in this order:
Small or too few ice cubes
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Specks in the cubes
If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
SOURCE: what temperature should my maytag
Your refrigerator temperature should be between 35-40 degrees F, the freezer should be 0-8 degrees F. Both of the control settings should be in the middle, so if its on a scale of 1-9, 5 is middle, if its on a scale of A-J, E or F would be the middle, if its a temperature setting, 37 and 0 is normal setting.
SOURCE: I have a GE Profile PSW23PSTA Refrigerator. The
ok.There is a water valve at the back of ice-maker unit.This valve open and the water enters the ice maker unit.This valve only opens when the ice maker has emptied the collected ice.But if in case this valve is not functioning properly and due to that very small amount of water is always entering the ice-maker unit and ice collected gets wet.So first thing to get the valve checked.Its a valve with twin nozzles.One goes to ice maker and one for water dispenser.In most of the cases this valve checked out faulty.But if valve checked out ok then other possibility to be checked is water fill tube which enters the ice maker section.If this fill tube is got kinked or its cracked then it will leak water to the ice maker section.------------- If any of the part checked faulty then you can get it from online site like www.repairclinic.com or
from searspartsdirect online site.---------This will help.Thanks.Helpmech.
