Question about Sommer 4054v001 two-button garage door opener remote - 310mhz
Genie intellicode medallion
Won't sync
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
Genie is not compatible with Sommer. They will never sync.
Posted on Jan 20, 2015
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
What size battery is used in the genie gitc390 remote
i buy a new battery for my genie gitc390 garage opener but still doesn't work, the red light is on when i press the button. what's the problem?
Nov 14, 2012 | Genie Company IntelliCode GICT390-1BL...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
Someone guessed our code and numbers were outlined with a marker.... we need to change code but lost our manual.
Hi
There is a bunch of manuals for Genie intellicode systems on genie's website just click here to go there.
Hope this helps
Mar 07, 2011 | Genie Company IntelliCode GICT390-1BL...
What battery is needed fir a Genie Intellicode model GICTD? My old one does not work and this is one is spare from my daughter, but it does not have a battery in it. gk
The battery can be changed. There is a divet on the side of the unit. Insert a flat screw driver and pop it apart. There is a number on the battery. I believe it is 2032. The number on the battery cannot be switched although other ones look like it. Thanks BB
Dec 31, 2009 | Genie Company IntelliCode GICT390-1BL...
How do you replace the battery in the genie garage door remote, its the small one
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Change battery in GICT390 3 button remote
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
Sommer 4054v001 two-button garage door opener remote - 310mhz Logo
Top Sommer Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Sommer Building Material Expert? Answer questions, earn points and help others
