Ipibl-lb does not power up - Computers & Internet
    Master:
  • 568 Answers
Check the cmos battery.
check the power supply
Posted on Feb 02, 2016
Want to replace Mcp7301h1 motherboard with ipibl-lb
you can technically put your M/B in there but you got to remember your CPU might be different and that also means that the chipset will also be different especially if it is Intel you have the socket that could be different and of course you've got to fit it in.
the one thing you have got right is you will need to reinstall the OS as the M/B + CPU + Chipset would require new drivers for them to work
Jan 10, 2014 | HP Computers & Internet
Manual for ipibl-la
Here you go :)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01077641&dlc=en
Aug 13, 2012 | ASUS Computers & Internet
Needna layyout diagram of the asus ipibl tx motherboard puhleeze
This is the closest I could find. I hope it helps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357064&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3824558#N443
Apr 16, 2012 | ASUS Computers & Internet
Need a good video card upgrade for my HP a6658f... one that will fit in the space provided and not require too much power (300 watt power source). The original is starting to go, and I would like to...
Your system has, from factory a Benicia #IPIBL-LB motherboard and has a PCIe x16 slot. You could go with any card PCIe x16 that is within your power range. I personally like the Gigabyte, Asus, Radeon HD cards because you can get sound and audio out of the card, unlike the Nvidia cards. The card you would more than likely be looking for would be a midrange card going anywhere from 40.00 to 90.00. There are many to chosse from but, I would get one that is Windows 7 or at least Windows Vista ready. This AMD's site and this card would work for you. It requires
300w supply and would do a good job.
http://www.amd.com/us/products/desktop/graphics/ati-radeon-hd-4000/hd-4550/Pages/ati-radeon-hd-4550-overview.aspx
May 24, 2011 | HP Pavilion a6658f Desktop PC
I have a HP P6140f. The only upgrade I have made was to the power supply and I added a graphics card (Radeon HD5770). It has been running stable for some time. I did a Bios update which syopped at a BSOD....
i tried to unlock my bios in my laptop and something like that happened to me too, and after some research i found out that i had probably fried the BIOS chip, wich can happened to you too, (just guessing), but anyway,theres a link for a new one:
http://www.bios-chip24.com/HP-IPIBL-LB-Benicia/pt
Apr 12, 2017 | HP DT PAVILION P6140f DESKTOP PC
Torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Jan 07, 2009 | 2004 Chevrolet Aveo
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
