Question about Suzuki Boating
Df70 cranks but wont start? ran fine 2 weeks ago. check engine light on, not blinking no audible sounds, 30amp fuse on engine is good
johnny_20
  • 161 Answers
SOURCE: honda civic wont start
You might have to change the spark plugs or at least have them cleaned.
Posted on Jul 12, 2008
  • 7 Answers
SOURCE: Mazda 2005 RX-8 wont start... ran yesterday, lights on & sounds
I have a 2004 that had the same problem. It sounds like the engine might be flooded. The best thing to do is to remove the fuse to the fuel pump. It will be listed under the fuse cover under the hood. Mine was a 20 amp but check to be sure. With the fuse removed, crank the engine for a minute to remove any fuel flooding the engine. Replace the fuse and crank the engine in 10 second intervals without touching the gas or you will reflood the engine. This process can sometimes take awhile and will drain your battery, so have it connected to an additional power source ( i.e. another car battery or jump box). When the car finally cranks over there will be a huge cloud of smoke so don't be alarmed when it happens. Lastly some words to the wise. This process CAN ruin your starter, but is essentially the same process that the dealership will you except that they will remove the spark plugs to drain the fuel and then charge you for new ones. If this process doesn't work then you probably need new spark plugs which is going to cost quite a bit. I was quoted upwards of $525 to fix this problem until I talked to a Mazda mechanic and found out how to do this myself. Just make sure that the engine is up to running temperature before turning the car off and you shouldn't encounter this problem again. I hope this helps you, and remember that if all else fails the dealer can fix it. It won't be cheap, but they will get it done.
I almost forgot, you HAVE to get the oil changed as soon as possible because there is probably gas in the oil now.
Posted on Dec 27, 2008
  • 341 Answers
SOURCE: gas not getting to engine
check the fuel pump relay... it is located under hood in fuse box
Posted on Dec 28, 2008
SOURCE: 1997 Jeep Grand Cherokee cranks but won't start
Same thing happened to me at about 140k. It was the fuel pump. Best way to test if your pump is failing and loosing pressure is to see if the car will start immediately after it has been running, or turn the key to the alt position for a few minutes before starting. If your engine fires faster after it has been running or the key has been in the alt position you will probably need a new fuel pump. Great news is with a very deep socket to get the tank straps off its a 30 minute job to replace the pump/filter assembly.
Posted on Dec 29, 2008
v2iper
  • 150 Answers
SOURCE: 1999 road king wont start
Its your fuel pump if you can't hear it. And its inside your tank. Not a hard fix if you have a book that tells you how to remove it. Alot of procedures to follow to get it right. And yes it does work off a relay.
Posted on Jun 14, 2009
Cranks but won't start
Depending on the year make and model, a DTC (diagnostic trouble code) would help. Is the check engine light on when it does run? Testing needs to be done. Check for spark at the plug, make sure fuel pressure is what it should be and that the fuel injectors are working. If all that is good, I would check compression and timing.
May 01, 2016 | Cars & Trucks
Car wont start flashers wont stop flashing. 97 GEO
double anon post.
backup one post and read.
left or right lights? if both that is HAZARDS stuck on.
cycle the hazard switch , bingo?????
there are 2 fuse, Turn, and HAZ, one must kill the blinking
which one? PULLED.?
you double post and ANON to boot., so here i ask again,.
it dont crank
or cranks ok fast but will not start.????
Sep 23, 2014 | 1997 Geo Prizm
98 dodge ram wont start but cranks fine
I havr a dodge ram 99 gas start good run good the problem is when i stay in a light w s itin the truck turn off only in gear
Mar 09, 2013 | 1998 Dodge Ram
93 honda accord wont start check engine light blinks rapidly
was there a solution to this one? my 93 accord lx is having the same trouble except it wont start at all now. ive got gas and spark and will crank but not start. wont throw a trouble code either just get the flashing CEL and clicking from control box which stops when the egr purge connector is opened. does anyone know the sequece of the egr/evap system. seems like something is getting hung up there. thanks
Jul 09, 2012 | Cars & Trucks
First of all. We have put 2 new starters on this car recently. We thought the first might have been a fluke. However we had the 2nd checked and it tested fine as did the battery and alternator. Problem is...
what do you mean by wont start?? engine cranks but wont run? engine wont crank? Is the anti-theft light flashing? is the car in park? did you put it in Neutral and try to crank it?
Nov 19, 2010 | 1992 Saturn SL
Gas not getting to engine
Dec 28, 2008 | 1998 Oldsmobile Bravada
Boating Logo
Top Suzuki Boating Experts
Steve
Steve
ray gallant
merc racing
Level 1 Expert
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
