Question about Garden
Engine starts but dies if you put a load on it such as putting it in gear or engaging the mower blade(its a rear engine rider) it did this 3 times, after the third time the spark plug wire started to smoke then it melted
    Scholar:
  • 81 Answers
Carb needs cleaned as it can't handle the load of the engine and the deck at the same time. My guess about the spark plug melting is that the electronic ignition may have become hot while trying to start the mower causing the wire to melt.
Posted on Jun 24, 2009
The rider mowers does not get in gear forward or reverse. The blade does engage. In neutral I tried to push the mower and it will not move because the rear tires roll in opposite direction.
Firts check your gear lever if is out of engaichmend,located on right hand rear side close to wheel shaft 2 check your belts 3 check your transmission fluits.
Jul 09, 2017 | Garden
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
Why will my Snapper riding mower not go into gear?
If it is a hydro-stat transmission, the bypass lever will have to be re-engaged for it to work.
Aug 23, 2014 | Garden
Briggs 407777, type 0121-E4
The engine is not developing power and the presence of a load causes it to slow down and quit all together. Is there some sort of timing advance on that motor? In a car if the timing is not right that is exactly what happens when you put the car into gear and try to use it.
I would not mess with the valves till I check out the timing.
Nov 24, 2013 | Briggs & Stratton Garden
My landlords toro riding mower starts fine but as soon as i touch the shifter to put it in gear it dies over and over..carb is clean and new gas with stabilizer
There are several safety switches that prevent operation in case the rider falls off, etc. First check seat safety switch...the likely culprit. It must close ensuring a person is in the seat for movement or blade operation. Find a toro wiring diagram, or visually wire trace, or just inspect the proper operation of all safety switches. DO NOT BYPASS SAFETY SWITCHES, but ensure they are working properly for SAFE OPERATION.
Nov 20, 2013 | Toro Garden
Mower dies when put in gear or blades engaged
check the safety switches try and bypass them one at a time to find the bad one
Apr 20, 2012 | Garden
Started up...then died as if safety switch 18HP craftsman rider
On later models there are possibly three safety switches, one under the seat, one for the blade engage mechanism or blade clutch so the blades don't turn when the mower is started, and a neutral safety switch to make sure the mower is in neutral before it starts.
Jul 07, 2009 | Garden
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
