Question about Nokia 9300 Smartphone
My nokia 9300 will not connect with my motorola bluetooth. How do I get the two to connect. Any assistance would be appreciated. Thanks
    President:
  • Nokia Master
  • 2,923 Answers
Try this:
1. Start with both phones turned off.
2. Then, turn both phones ON.
3. Enable the Bluetooth of the Motorola phone first.
4. Search for the Bluetooth devices in range using the Nokia 9300.
5. Once the Motorola phone's detected, pair them up using either '1234' or '0000' (without quotes).
Hope it helps and have a good one!
Posted on Jun 23, 2009
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
I am unable to connect bluetooth n95 with my nokia 5800 mobile
Hi unto,
First switch on both the bluetooth and check from each other whether the other device is detected, and then pass the data you would like to pass, if still it does not work some settings will be wrong, so reset both the device and do the settings from the start.
Please leave me comment, if you need further assistance
good luck with your fix.
have a nice day.
A VERY HELPFUL RATING IS APPRECIATED,
Thanks
Regards
Arul
Mar 13, 2010 | Nokia 5800 XpressMusic Smartphone
Motorola Bluetooth Won't connect
hello there! there are actually several cell phone brands that don't have any easy access if opening the blue tooth..one of its main reason is that some phones are just reconditions. in your case, try consulting the nearest center wherein you had purchased your phone and inquire on how you can on your bluetooth. it happened to me already with my nokia recon phone, i can't work my blue tooth myself so i tried asking the assistance of a nearest gadget center and poof! they solve it right away. for more inquiry, please keep in touch with me. thanks!
Apr 10, 2009 | LG Shine CU720 Cellular Phone
Bluetooth of my nokia 9300 doesnot detect or get detected by other dvices. No virus. Formatted but same result. Pls help
You might have switched on the bluetooth but kept in hidden mode. try checking the bluetooth setting and change the mode to visible mode. Then your mobile should be detectable by other mobiles
Mar 17, 2009 | Nokia 9300 Handheld
N72 - Not able to Connect Motorola Bluetooth Headset ( H500)
Hi
My cellphone Nokia N72 is not paring with Nokia -BH-102.
When i began to search , but it not connecting
By Vijeesh
Jun 24, 2008 | Nokia N72 Cellular Phone
Internet problem
Its very simple download and install the latest version of Nokia PC suite. PC suite has a menu "Connect to Internet" As long as your phone connected to PC via USB cable or Bluetooth you will have the connect to internet option working. It will give you also auto setting option as I have tried it with Smart and Globe both of them worked well. You can download PC Suite at www.nokia.com.ph
Good Luck
Dec 29, 2007 | Nokia 9300 Handheld
Motorizr connecting to a nokia bluetooth
best to take in store and have csr assist.
you should turn on the bluetooth on the phone search for the headset, when it ask for the passcode enter 0000
Dec 07, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Nokia 9300i
Yes! 9300I Bluetooth Supported Profiles: HFP, DUN, OPP, FTP, SAP version 1.1 (9300) / version 1.2 (9300i) Are you familar with how to set them up?
Sep 13, 2007 | Motorola Mobility H700 Wireless Headset
Nokia 9300 Smartphone Logo
87 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
