Question about NewAir AW-211ED 21 Bottle Wine Cooler
Why are the wine cooler lights' blinking? - NewAir AW-211ED 21 Bottle Wine Cooler
I have a Master Cool cooler and thermostat and I have never seen this before. Lights 7 and 8 are blinking red. What does this mean?
If you don't have user's manual or if doesn't mention the meaning of blinking lights, look al manufacturer's website, for "Contact Us", see if they have a cusomer's service phone number or a way to leave them a message.
Sep 06, 2015 | Furniture
Tech digital radio
That's a good question! First we have to find out if the light is part of a low temp circuit. If it is then I would look at replacing a low temp switch if it has one. The fact that it's still keeping wine cool tells me it either doesn't have a (LTS) or it isn't working. If you can find out where the wires from the light are located I would just cut a wire and tape the loose end with electrical tape. Its likely that its nothing but a warning light. One other option is to black out the light with paint or tape.
Aug 27, 2014 | Danby DWC1233BL-SC MaitreD 12 Bottle Wine...
Temperature lights blinking
Did you ever get any info on this problem? We are having the same issue. Thanks
Mar 16, 2013 | KitchenAid KUWA244PBS Wine Cooler
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
I always thought that light was bad for wine. Why is it that almost every wine cooler is look at has bright lights built inside?
The lights in a wine cooler are LED lights. These are safe forms of lighting to use as they will not raise the temperature of your wine.
Jul 31, 2012 | Furniture
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
Short maybe?
check voltage on outlet is grounded properly try another outlet
Nov 03, 2008 | Haier BC112G Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
Change light in wine cooler
Took everything out and got on my back with flashlight to find a tiny screw holding lens in place.  Found that a little night light fit and worked fine.  Wish the manual had a simple direction to fix the problem.
Jul 03, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
NewAir AW-211ED 21 Bottle Wine Cooler Logo
42 people viewed this question
Top NewAir Heating & Cooling Experts
Donni Steen
richie46
Tom Chichester
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
