Question about Samsung Un60d6000 60 Inch 1080p Led Hdtv
Samsung smart activar opciones difusion audio TV UN60ES7150
Tip
How to find out the series number and model code of a Samsung Smart TV
1. From your Smart Remote press the Menu button
2. In the menu displayed in the TV , select the support option
3. Select Contact Samsung option in the Menu
This displays the Model number / code, firmware version and other details of the TV. Scroll down the popup menu to view other details of your TV.
on Jan 09, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Tip
How to Play iTunes DRMed Movies on Samsung Smart TV via Mac
Apple makes its digital content too proprietary so that we can't enjoy any content we purchased or rented from iTunes store on any other Non-Apple products. It of course won't allow us to watch the iTunes movies on Samsung Smart TV.
But this will make Samsung Smart TV users depressed if they have purchased or rented movies frm iTunes store. This tip is written to help the Samsung Smart TV users to solve the issue.
Method 1. Transfer the iTunes movies to Samsung Smart TV using an USB port.
If you have a smart tv on hand, you will see there is a USB port on this TV. So we can transfer content via USB port to this TV set. But iTunes movies are DRM protected, we can't transfer it directly. So it needs us to remove the DRM at first. TunesKit iTunes DRM Removal application is a must-have tool for Mac users.
iTunes DRM Removal for Mac Remove DRM from iTunes Rentals and Purchases...
Step 1. Download and install the TunesKit DRM removal software on your Mac
It works with Mac OS X 10.8 or later and the newest iTunes. The Windows version is coming soon.
Step 2. Add iTunes M4V videos to TunesKit
Click "Add Files" icon, you can add iTUnes movies from iTunes library directly. Or you can also drag and drop the movies to TunesKit.
Step 3. Manually choose output subtitles, audio tracks and AC 3 adolby 5.1 surround
If you don't want to output all the audio tracks, subtitles in the MP4 video. You can manually choose the audio tracks, subtitiles or 5.1 surround, stereo channels for the output.
Step 4. Start removing DRM protection.
Click "Convert" button to start removing iTunes drm protection from iTunes movies now. Once the conversion done, you can find the output MP4 video under the "Converted" tab or clicking "Open" button.
The output MP4 videos are totally DRM free and 100% original quality preserved. You can copy and paste the videos to USB now and plug the USB device to Samsung Smart TV.
For more methods to watch iTunes movies on Samsung Smart TV. You can refer to this page: How to Watch or stream iTunes DRM Movies to Samsung Smart TV
on Aug 20, 2014 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
How do connect Sony audio receiverstr-k670p to Samsung smart tv?
Both should have an optical audio jack. Easiest way to hook the two together
Jul 28, 2015 | Sony Str-k670p
Hook up samsung sound bar to lg smart tv
easiest way would be to connect the optical audio output from the tv to the optical input on the soundbar. You may have to go into the tv's setup menu and enable the audio output jack
May 10, 2014 | Samsung HW-D450 Sound Bar
Como activo el bluetooth? No puedo enviar ni recibir datos. Gracias
busca el simbolo del bluetooth y ahi buscas donde diga activar, por lo general esta en opciones o algo asi y de ahi lo activas. para recibir datos algunos celulares los tienes que hacer detectables busca si tu telefono tiene esa opcion y ya de ahi todo es facil espero te sirva la informacion
Dec 18, 2010 | Cell Phones
No puedo activar Microsofft Office ni tampoco HP
eso es normal, los nuevos computadoras por lo general sólo se suministran con un juicio 30 días de la oficina
Puedo descargar la oficina abre de http://www.openoffice.org que es un programa gratuito que es similar a microsoft office
Mar 20, 2010 | Microsoft Windows Vista Home Premium with...
Hola a todos, tengo un problema con el icono de la bateria de mi portatil. este desaparecio de un dia para otro y no hay caso de volverlo A Mostrar. en las Propiedades de la barra de tareas y menú...
lo siento, pero mi espanol no es muy bien. Para este problema, nescecitas vas al "Control Panel" > "System Settings" > "Power Settings". Perdon, pero no conozco este nombres en espanol. Tengo windows en chino y alman, pero no espanol :P.
Primero cambiar este cosas, y despues propiedades de la barra.
Jan 09, 2010 | Microsoft Windows Vista Home Premium...
Samsung Un60d6000 60 Inch 1080p Led Hdtv Logo
26 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
