Question about Asus US EB1503-B003G Atom D2550 Nettop
Eject button doesn't work
The dvd eject button does not work
Tip
If your Xbox 360 Disc tray won't eject
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on Feb 02, 2010 | Video Game Consoles & Games
Cannot find eject button or what to use to eject DVD from bauhn atv-32hdc1n. Lost the manual first time to use DVD and now cannot get it out. Hope you can help
On page v of the manual (if you had one), under the heading "DVD Mode", the first item in the list is an up-arrow symbol, with "Press to eject the disc" next to it.
That's simple enough, IF you have a user guide. But if you don't, and you weren't familiar with standard symbology for these types of buttons, you would be stumped by the moronic design of the remote control.
The up-arrow button is on the top row of the Remote Control buttons, next to the red Standby button. It's a standard Eject symbol, but not only did they just assume you'd know that, they obfuscated the situation further by marking it as "TV/Radio". So if you weren't familiar with the symbology, you certainly wouldn't be looking for something marked TV/Radio to eject a DVD.
But there's another catch: The up-arrow/eject button will only work if your Source is set to DVD. If for any reason you switched away from the DVD before wanting to eject it, you would find that the Eject button no longer works. You have to switch back to Source = DVD, then press the eject button.
IMO, there is no excuse for a Remote Control design that can't be figured out without the manual.
Aug 28, 2013 | Televison & Video
Cannot remove dvd
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Performance chips for ford
Jun 12, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
Aug 16, 2011 | Computers & Internet
Player seems to have eaten the DVD. Will not release it so can be ejected
If it's a desktop, you can manually eject the disk. Turn off your computer and press a paper clip or other small object into the little hole on the front of the DVD drive. You need to apply a little force, but the tray should slide out far enough for you to remove the disk.
Jul 18, 2011 | Computers & Internet
How do I open and close my dvd player using the remote control
This Model doesn't have an Eject Function on the Remote Control.
They work on the principal that if you're changing the DVD then you'll be by the Player anyway to use that Eject Button.
Jun 03, 2011 | Sony DVP-SR500H DVD Player
Go Video DVD will not eject
this suggestion made on this forum worked great for me.
I don't care if it does sound silly.. smack the unit smartly over the eject tray when you press the eject button.
Dec 23, 2008 | GoVideo Go Video DVD/VCR Combo
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Asus US EB1503-B003G Atom D2550 Nettop Logo
26 people viewed this question
Top Asus US Computers & Internet Experts
David Payne
David Payne
Are you an Asus US Computer and Internet Expert? Answer questions, earn points and help others
