Question about GPX BC232R Radio CD Player Boombox
Is this battery operated or by electric? - GPX BC232R Radio CD Player Boombox
07 chevy uplander ran out of fuel,with 1/8 tank on way,to store now the battery save active displays when I attempt to start the van like,it set off an alarm. How can I get it running
Battery Saver Active
Refer to Charging System Description and Operation
The BATTERY SAVER ACTIVE message will display on the driver information center (DIC) when the vehicle enters a load shed 2 event. Refer to Load Shed System Description and Operation for load shed 2 setting criteria.
Electrical Power Management
The electrical power management (EPM) is used to monitor and control the charging system and alert the driver of possible problems within the charging system. The EPM system makes the most efficient use of the generator output, improves the battery state-of-charge (SOC), extends battery life, and manages system electrical loads.
The load shed operation is a means of reducing electrical loads during a low voltage or low battery SOC condition.
The idle boost operation is a means of improving generator performance during a low voltage or low battery SOC condition.
Each EPM function, either idle boost or load shed, is discrete. No 2 functions are active at the same time. Idle boost is activated in incremental steps, idle boost 1 must be active before idle boost 2 can be active. The criteria used by the body control module (BCM) to regulate EPM are outlined below:
I dought you will be able to get it running , except by luck . The best thing you could do is have a qualified repair shop diagnose it . The first place to start would be to hook up to a factory diagnostic scan tool , Check for DTC'S - diagnostic trouble codes .
Jan 28, 2017 | 2007 Chevrolet Uplander
Where are my water PUMPS
I don't know but if you are talking about the Astra Innovative Electric Battery-operated Home 5 Gallon Jug's water pump, it is in the top section.
Aug 16, 2014 | Astra Innovative Electric Battery-operated...
How to replace the battery on a bbq electronic ignition
Most of them don't have a battery at all. They operate by piezo-electric ignition. When you operate it, a spring strikes a crystal with a little hammer, and this causes a discharge of voltage and a spark. If it has ceased to work, there is an adjustment you can do
https://www.youtube.com/watch?v=c_sEDsyOCzE
or replace it cheaply
http://www.theartofdoingstuff.com/karen-answers-how-to-replace-a-busted-bbq-ignitor/
Mar 22, 2014 | Kitchen Appliances - Others
Battery not charging
If a battery seems unable to hold its charge, it may have a defective cell or an electrical short that makes normal operation impossible. Check the electrical system. A faulty car electrical system may also cause premature power drainage. Battery terminals may grow dirty or develop corrosion, interfering with proper performance and causing the battery to deliver more power than the situation actually requires.
Aug 07, 2013 | Cars & Trucks
Replaced the k134 car cuts off after engine gets hot. guessing 40 minutes of driving
The battery in most cars is used only for starting and operating electrics when the engine is not running.
After that, the alternator provides power to operate ignition and electric systems - and of course; recharge the battery. A faulty battery shouldn't cause the car to stop running. If the alternator is not functioning properly, the car will get power from the battery instead. When this happens, the voltage will drop quickly - depending on how many electrical accessories are on, etc. You will notice headlights becoming dim at night just before the engine quits. The car would not be able to start / run until the battery is recharged.
Nov 08, 2012 | 2000 Cadillac Catera
How do tent fans work? Do they need electricity or batteries?
Tent fans work with batteries (as people who use tents are usually away from electricity plugs...)
These fans usually operate on 4 or 6-D cell batteries. I recommend taking some extra batteries with you if you are going on a trip, you never know when you will need them.
Jul 10, 2012 | Camping, Backpacking & Hiking
My mecedes car wont start properly outside my house but will do at my mums... the school next door to me have fitted electric gates. could this be draining my battery over night... it only started when...
Unlikely that the electric gates would cause the problem. You could try parking a bit further away from your house (friend ?) just to see if it makes any difference. Also, if you have the original battery it is probably coming to the end of its life cycle and may not hold a charge as well as it should, Even something as simple as dirty terminals can affect the starting efficiency.
The gates are operated by small electric motors that would only send out very minor frequencies and only when in operation. Very unlikely they would affect your car.
Nov 23, 2010 | 2006 Mercedes-Benz Mercedes Benz CLS500
How to change the radiator fan?
Electric Engine Fan - Fan Switch
Removal & Installation
2.7L Engine
  1. Disconnect negative battery cable.
  2. Partially drain cooling system.
  3. Disconnect the electrical connector .
  4. Remove engine coolant sensor from coolant outlet tube .
To install:
  1. Apply thread sealant to sensor threads.
  2. Install engine coolant temperature sensor into coolant outlet tube.
  3. Tighten sensor to 20 ft. lbs.(28 Nm) torque.
  4. Connect electrical connector to engine coolant temperature sensor .
3.2L And 3.5L Engines
  3. With the engine cold, disconnect coolant sensor electrical connector.
  4. Remove sensor.
To install:
  1. Install engine coolant temperature sensor.
  2. Tighten sensor to 20 ft. lbs.(28 Nm) torque.
  3. Attach electrical connector to sensor.
  4. Connect negative battery cable.
  3. Remove upper radiator hose.
  4. Disconnect cooling fan electrical connector.
  5. Remove cooling fan mounting bolts.
  6. Remove radiator cooling fan assembly from vehicle.
    Fig. Removal and installation of the radiator fan-2.7L Engine shown
To install:
  1. Position radiator cooling fan assembly in vehicle.
  2. Install cooling fan mounting bolts. Tighten to 50 inch lbs. (6 Nm)
  3. Connect cooling fan electrical connector.
  4. Install upper radiator hose .
  5. Fill cooling system.
  6. Operate engine until it reaches normal operating temperature.
  7. Check cooling system and automatic transmission for correct fluid levels.
Hope helps (remember comment and rated this).
Jul 13, 2010 | 2001 Dodge Intrepid
Need to test Hoveround mpv4, batteries are dead
No you will have to have proper working batteries.
Mar 19, 2009 | Electric Mobility Power Electric Scooter...
Electric scooter battery problem
Some low end electric scooter provide 200-400 full charge-discharge cycles for a battery. Many scooter batteries will operate over 500 times.
Aug 27, 2008 | Drive Medical Sun Shade for Scooter - 1...
GPX BC232R Radio CD Player Boombox Logo
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
